Toe In question
To get it closer, I centered the steering wheel and holding a long straight edge from front tire to the back tire I could see that the DS was pretty much straight. The passenger side was turned outward, so I adjusted the tie rod end to also get it pointed straight ahead -it worked great and the steering wheel was centered and the car tracked staight.
All good at this point and I brought the car in for an alignment -they did it and it feels just as good as when I did it. Again, everything is good.
However, I was turning right into a parking space today and it felt as though I was not able to turn tight enough. I went home and measured and the wheels turn about 1" farther to the left than to the right.
What did I miss?? and how do I correct it?
Thanks, Glen
Just had a thought, do the tie rods look to be out about the same amount? If there's a big difference side to side, that could cause the same problem.
Can the slip joint be installed in many different ways?Or can it be only installed one way?I know some cars there is a flat spot or hole on the input shaft on the rack & on some cars it can be installed 20 different ways
If your car is airbag equipped possible clock spring damage can occur as its ment to be able to do only so many revolutions-this is an extreme case & if only off a couple of teeth,won't cause this problem.Clockspring damage can cause airbag deployment
Again, I have the Z51 option and the attachment of the steering wheel column to the input shaft of the rack only lines up one way... as far as I can tell.
Right now;
The wheel is centered.
The tires are straight ahead.
It drives and feels perfect.
Each outer tie rod end has about 1/2" of exposed thread.
If I rotate the steering to the left, I get exactly one revolution.
If I rotate the wheel to the right, I get about 2/3 of a revolution.
Does this mean that when the rack was rebuilt, the internals were not assembled correctly?
If so, is it possible to correct it or do I bring it back to NAPA for a replacement?
Thanks, Glen
1) I can't find the specification for 84 Z/51, but I believe that the steering wheel lock to lock, should be 2 rotations? That would definitely prove your point that something is binding internally if I can only get about 1 2/3 rotations
2) Is there anything external to the rack that limits the steering linkage travel?
But I would definitely go to a shop (that knows their stuff) and get a 4 wheel laser alignment. As much as any of us knows about cars and our abilities there is no substitute for doing the job right and having the correct equipment, which none of us probably has.
That and tires is about the only time anyone else works on my car. Some job are just not feasible to do it yourself and get it right. Some things I will pay the well spent money for. It is a small expense to what I save maintaining the car myself.
If after the alignment there is still a problem, it may be easier to find. Or the alignment person may actual identify the problem or repair it if simple.
I'm trying to detemine if the rebuilt rack is bad, which means that I'll have to pull it out and get NAPA to replace it.
