? ABOUT GEARS
Old Mar 18, 2002 | 08:57 PM
CORVETTE MIKE's Avatar
CORVETTE MIKE
Default ? ABOUT GEARS
Iam going to go with 3.54 gears from 2.59 ,my question is will my hypertech power programer fix my spedometer or will i have to do something else? THANKS MIKE
Old Mar 18, 2002 | 09:04 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: ? ABOUT GEARS (CORVETTE MIKE)
Heypertech should work for ya. :cheers:
Old Mar 18, 2002 | 09:55 PM
red-y's Avatar
red-y
You will love this modification.. :crazy:
Old Mar 18, 2002 | 10:57 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
I believe the hypertech is only calibrated for the 3:45's....you will have
to play with the tire size. There is a formula out here on the forum somewhere....I believe... :)
Old Mar 18, 2002 | 11:35 PM
CORVETTE MIKE
Default Re: ? ABOUT GEARS (Vette Ed)
I just hooked my hypertech programer up to check the options and there is a 3.54 option,so do you think it should be ok?
Old Mar 18, 2002 | 11:46 PM
cprgmr's Avatar
cprgmr
Sounds like it'll work. I wish it was that simple for me - I have to change at least 2 gears at the back of the tranny when I do mine... :(
Old Mar 19, 2002 | 01:50 AM
Goody's Avatar
Goody
Default Re: ? ABOUT GEARS (cprgmr)
You are in there. A4 folks pre 94 should just do the gear swap in the tranny as well as the VSS. Contact 18carfan for the parts real cheap. Easy job....love the results. :yesnod:
To ? ABOUT GEARS
