headlight problems 87 vette
Old May 25, 2010 | 02:30 PM
Dyno Jim's Avatar
Dyno Jim
Default headlight problems 87 vette
Just purchased a 87 cpe. only 67,000 miles, runs great, looks great,
retail red with red sports seat etc. Now here's my problem turn the
light switch on and I get nothing no light no movement of the light
housing 0. Don't know much about C4's this is my first and no owner
manual with car, I've pulled fuses in fuse box on passager side and
everything looking good. I've pulled the relay cover on drives side
fender well and I'm not sure what I'm looking for but all wires and
fitment looking good. If anyone can give me a direction to repair I
would appreciate it greatly. I also have a C5 99 conv. I've had the
front on and off several times but never had this problem with the
lights. Thanks Again
Dyno Jim
Oklahoma
Old May 25, 2010 | 07:31 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If the fuses and fusible links are OK, you're probably going to have to get to the headlight switch and check for power in and out. A shop manual will come in handy.
Old May 25, 2010 | 10:56 PM
rodj's Avatar
rodj
As neither the doors or the lamps work most likely at the switch or it's 12V supply which is direct off the starter terminal.Two independent systems from the one switch.
Old May 26, 2010 | 07:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old May 26, 2010 | 08:47 AM
Dyno Jim's Avatar
Dyno Jim
thanks for the diagrams. Replaced the dash light switch and everything good now.
Thanks everyone for the help I do really apreciate it.
Dyno Jim
To headlight problems 87 vette
