Heater Core...
Old May 29, 2010 | 10:48 PM
White Lightnin's Avatar
White Lightnin
5th Gear
Default Heater Core...
so, My AC spews antifreeze smelling fog, and there's the tell tale fog on the windsheild after she sits for awhile after a drive.
The research I've done all points to the heater core. I've read the thread here where I can access it with the passenger seat out and a few components from the underside of the dash...
the thread was kinda dated....anyone got any advice before I get started?
(89 coupe)
Old May 29, 2010 | 11:17 PM
Azriel's Avatar
Azriel
(89 coupe)
I'm 20, and have no formal mechanical training or experience prior to owning this car, which I got in January. I did it myself. It took a total of something like 12 hours, including a break to go to a coworkers house for a few hours. It's honestly not bad if you follow the guild, label everything you take out, and be careful to not break anything.
When I did mine, there was some foam sh#^ that disintegrated and came out. I didn't bother replacing it, but I probably should have. I think it was a sort of seal between the heat/ac components.
Also, when you go to physically remove your heater core, the hoses clamped to it will be stuck. I cut mine, but I heard you can heat them or something like that to get them loose. Be careful of the clamps, if you lose grip on one, it can snap open and pop a hole clean in your big black AC box thing.
Good luck friend!
