Drilling Thermosat
Old Aug 3, 2010 | 12:41 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by slickfx3
going to drill mine where do you drill? drilling robershaw type milidon unit
Here you go
Old Aug 3, 2010 | 12:52 PM
ddahlgren's Avatar
ddahlgren
Originally Posted by pmihaltian
Here you go
I have been doing like that sine around 1964..LOL Yes I am that old.. sigh..
Old Aug 3, 2010 | 01:14 PM
mdlfcrss's Avatar
mdlfcrss
Thats funny...I was going to say that I remember doing that back in the early 70's... I guess you're older than I am!!!
Old Aug 3, 2010 | 02:02 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Turbo,
figure your car should run 100 degrees over outside air while driving on freeway.
Slightly higher on rubberized asphalt. higher yet on piestewa peak at the curve going north.
So your car should be at 205-210 degrees on a 110 degree day on freeway. 225 in stop and go.
With an all aluminum 2 row, and a 170 t-stat, 90 degrees outside, my 86 runs at 175 degrees on fwy.
At 109 degrees, it runs at 189 on fwy. In stop and go, it runs at 195.
Old Aug 3, 2010 | 02:41 PM
JAKE's Avatar
JAKE
According to TPIS's instructions - which is where I first learned of this procedure, it's actually a TWO PART mod.
Not only are the two holes drilled (different sizes based on the ambient temperature expectation) but the by-pass hole behind the passenger side leg of the water pump should be plugged.
That makes the job a lot more involved; pulling the W/P and re-installing it.
Jake
Old Aug 3, 2010 | 03:36 PM
redrose's Avatar
redrose
why else would you drill for other than to bleed, why did you drill it so big?
non-drilled t-stat, using a good temp gauge with a good sensor, sensor located correctly, and paying close attention: coolant temp will rise above t-stat rating on a cold start...then drop below t-stat rating...after a number of 'excursions' the gauge will stabilize...hi probability that the pistons/ heads/ etc are seeing a roller coaster of temperature/clearance changes, also.
drill the t-stat and engine warm-up to 'normal op temp' will be slightly longer but without overshoot/undershoot of coolant temp...better for the engine but vehicle occupants may complain of reduced cabin heater enthusiasm in low ambient conditions.
fwiw, our testing showed that with four 3/16'' holes in the t-stat, ambient 85*F, light engine load: coolant temp never reached the t-stat rating (too much not always a good)
Old Aug 3, 2010 | 04:07 PM
JAKE's Avatar
JAKE
Originally Posted by bryanjamesjr
Congratulations. That is a huge lifetime achievement. God Bless Him. My son also went to West Point, Jason Verkay,Class of 95 I think it was. Was in Special Forces, Rangers, fought in Macedonia and Bosnia. Came out a Captain and works for Capital One now. He bought me the house I live in. Great people go there and even greater people come out.
That also reflects on the fine up bringing your son had. He will need as much support as you can give him now, and I will have him in my prayers. You will see that they take care of their own now, and anything I can help you with do not hesitate to contact me, Welcome to the Family. Brian Verkay Sr.
Thanks for your comments, Brian. I'll be sure to pass them along to Ryan. Congratulations to you and your son too. I totally agree with your "Great and Greater" comments. The Point's REALLY got it going-on.
Right now Ryan's attending a 4 month training program at Ft. Lee, VA. Won't be back to Ft. Hood until November.
Jake
Old Aug 3, 2010 | 04:33 PM
Charleston2012's Avatar
Charleston2012
If you are just trying to bleed air, do it this way.
With a cool engine, take radiator cap off.Then start Vette, turn heater on full. Rev engine to about 1500 ish, then when temp gets to where the thermostat opens, you will see flow and then add distilled water as necessary to fill her up. Thren, once full, put radiator cap back on.
Reduce rpms. Radiator system is now fully packed.
Old Aug 3, 2010 | 05:17 PM
tblt44's Avatar
tblt44
Does anyone know if the failsafe stat has a hole in it.
You can buy it thru autozone.com.
Has anyone used it or recomend it??
Old Aug 4, 2010 | 03:37 AM
samsonb's Avatar
samsonb
Some stats already have a hole with a jiggle valve in it. The Duralast stats at Autozone have this jiggle valve. I believe they are made by Motorade. Though, I went with Stant and drilled a hole.
Old Aug 4, 2010 | 12:26 PM
JAKE's Avatar
JAKE
I have and am using one of those and, no hole. Most auto stores sell them; Advance, O'Reilly's and yes, AutoZone.
I recommend them because I've had a NON Fail-Safe version fail on my while driving down the road IN THE CLOSED position. Almost left me stranded.
I was able to wait out the time for cool down and finally made it home with the temp at 260F!!!
Jake
Old Aug 4, 2010 | 02:56 PM
94vettelover2's Avatar
94vettelover2
Originally Posted by JAKE
Yes.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Jake,your son in the pic looks like he could kick some ***-especially mine
Old Aug 4, 2010 | 07:46 PM
  #33
JAKE's Avatar
JAKE
[QUOTE=94vettelover2;1574908291]Jake,your son in the pic looks like he could kick some ***-especially mineQUOTE]
Let's hope it doesn't come to that, LOL.
Black Belt, Tae-Kwon-Do, hard as a rock thanks too the Army's physical training.
Jake
Old Aug 5, 2010 | 02:26 PM
  #34
samsonb's Avatar
samsonb
Jake
I never got one of those because I've heard alot of reports of them failing in the open position far too often. Like in a few months. Sure would suck to have to keep replacing a stuck open thermostat over and over again.
Old Aug 5, 2010 | 04:11 PM
  #35
JAKE's Avatar
JAKE
Yea, I had one do that too, but, hey, consider the alterrnative. Getting stuck when one fails in the closed position, as happened to me.
Jake
Old Aug 5, 2010 | 04:15 PM
  #36
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Huh? What makes you think a fail-safe open stat is any more likely to fail than the opposite type?
BTW,,,Anyone ever consider that 3/8" burp holes might let your stat perform like a 160-degree stat? Better yet,,,if you run one that stuck open, it's like a 0-degree stat! What's the problem?!?!?
Old Jun 11, 2013 | 11:42 AM
  #37
Gear nut mike's Avatar
Gear nut mike
1st Gear
This is C6 dose that mater if I drill a 3/32 hole.
To Drilling Thermosat
Old Jun 11, 2013 | 01:02 PM
  #38
JoeUser's Avatar
JoeUser
Sounds exactly like my '96 (only I'm running a Hypertech 160* stat and a DeWitt's new model single-row radiator). Sounds like mine is about as close to your mentioned specs as can get
I was wondering about benchmarking, as I wasn't sure whether I was getting the best cooling efficiency out of mine, but looks like I am getting similar specs. Thanks for the confirmation.
Old Jun 11, 2013 | 03:57 PM
  #39
ddan's Avatar
ddan
Sound right for me also... I'll run 205-209 on freeway until stop and go driving then from 211-225. Last year changed to a 160 tstat (with hole), drained, flushed and replace coolant... then noticed plastic bag and paper stuck on the radiator (was running 235+)
Just a side note, do you Phoenix guys go to the Pavilion in Scottsdale on Saturdays?
Old Jun 17, 2013 | 10:01 PM
  #40
Scootin_Z's Avatar
Scootin_Z
I want to pull mine and check it. Why is there 2 different stats shown in this thread? Just curious....
