check your spare
Old Mar 20, 2002 | 12:09 PM
fiddleplayer's Avatar
fiddleplayer
Default check your spare
I checked my spare tire on my 86 for the first time since I owned the car, two years now. Not only was the
tire flat but the top bead had broken loose and the tire was filled with water!! Must have weighed 40 pounds!!!
Old Mar 20, 2002 | 12:11 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: check your spare (fiddleplayer)
:eek: That sucks!! :mad
Thanks for the reminder! :cheers:
I have mine in storage so I forgot about that thing.
Old Mar 20, 2002 | 12:18 PM
BobMachus's Avatar
BobMachus
Hmm...that will slow ya down. Probably hook up great tho, and good for snow traction :lol:
Old Mar 20, 2002 | 12:26 PM
fiddleplayer
Default Re: check your spare (BobMachus)
I'm taking it in to get it broken down to see if the rim is ruined. The tire looks pretty well gone. I don't know if you can buy one
of these tires or if you have to buy the tire and rim together. It doesn't look like the tire has ever been used.
Old Mar 20, 2002 | 12:30 PM
KYVette90's Avatar
KYVette90
When I first checked mine out it looked like a squirrel or a chipmunk had stored 40lbs worth of nuts in there.
Old Mar 20, 2002 | 12:31 PM
87SAM's Avatar
87SAM
Pulled my this winter and the bead had broken loose also, no water though. Tire shop reseated it for free :D
Now one of these days I need to get the lug wrench that goes with it :crazy:
Old Mar 20, 2002 | 03:05 PM
fiddleplayer
Default Re: check your spare (87SAM)
the lug wrench on my 86 is fastened in the well behind the passenger seat.
Old Mar 20, 2002 | 06:57 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
i plan on removeing my spare & the ugly cover that hides all the beautiful suspension parts, not only will i shave weight but everything (suspension parts) looks awsome if you polish it.jd did this to his vette & i will soon follow. :yesnod:
Old Mar 20, 2002 | 07:36 PM
J Z06's Avatar
J Z06
Default Re: check your spare (yoslambo1@cs.com)
I just checked my spare...I can't find it! :lol:
Old Mar 20, 2002 | 08:18 PM
siberianhusky911's Avatar
siberianhusky911
Do you need that plastic cover for any thing. I already removed my tire but i wasnt sure if u could take the holder off? If so off it goes :seeya
Old Mar 20, 2002 | 08:32 PM
65Z01's Avatar
65Z01
Ok, I'll take a look at mine; it's about 10ft from me as I type.:jester
I did the spare & jack delete over a year ago but left the carrier for that "stock" look with out the extra 50lbs of weight.
Old Mar 20, 2002 | 08:44 PM
KYVette90's Avatar
KYVette90
Default Re: check your spare (65Z01)
Yes you can take the carrier off, four bolts, two each in each bracket. Nice work JD. Did you take it all apart to detail it?
[Modified by KYVette90, 6:53 PM 3/20/2002]
Old Mar 20, 2002 | 08:51 PM
ittlfly's Avatar
ittlfly
Default Re: check your spare (JD 90 383)
My goodness that is bright. Just where do you install all the batteries to keep it shinning? In that big thing in the center? :lol: Just kidding, looks real nice and a awful lot of work.
Old Mar 20, 2002 | 09:19 PM
OrangeC4's Avatar
OrangeC4
Thought I would never say this to a guy, and never will again, but. Nice looking rear end. :lol:
Old Mar 20, 2002 | 09:39 PM
Rich B.'s Avatar
Rich B.
Nice polish job, but...
...Ugly clamps... :nonod:
Borla has some really nice stainless strap clamps... :yesnod:
Old Mar 20, 2002 | 09:42 PM
J Z06's Avatar
J Z06
Default Re: check your spare (Rich B.)
Donno why, I edited it and said I deleted the clamps...simply put a bead of weld on there now,and things are good. Just a little scubbin' some mothers polish and thats how things turned out. The mounts are Red becuase I wasn't sure I was going to go Admiral Blue.Still looks good though :D
JD
Old Mar 20, 2002 | 09:52 PM
Rich B.'s Avatar
Rich B.
...Huh???... :confused:
The rusty muffler clamps in the pic are gone? You welded the pipes?
OK; I think I can visualize it...Nope, I still see the rusty clamps... :D
Old Mar 20, 2002 | 10:16 PM
pablocruise's Avatar
pablocruise
WOW JD!!!!!!!!
That looks soooooo good!
I am gonna go take off my carrier now too! Maybe I'll polish also.
Cheers to you for all that work!
since some nitpicking is going on :D :jester there is one bolt on the rear cover that is black and the others are shiny. :crazy: sorry 'bout that
Old Mar 21, 2002 | 02:56 AM
GlockLT4's Avatar
GlockLT4
To check your spare
