High Fuel pressure
Old Jun 17, 2010 | 07:03 PM
clambake0000's Avatar
clambake0000
8th Gear
Default High Fuel pressure
Can any one tell me why after replacing the elect. fuel pump I have fuel pressure that pegs a 80 psi gage?
However the motor dose start now and seems to run just fine. But it is the fuel pump that I am worried about and am wondering if that is the cause of the original one failing.
Old Jun 17, 2010 | 08:31 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
May be the FPR, never heard of 80 PSI on one of these cars.
Old Jun 17, 2010 | 09:04 PM
dogfish246's Avatar
dogfish246
FPR = Fuel Pressure Regulator (just in case)
Old Jun 18, 2010 | 07:37 AM
runner140*'s Avatar
runner140*
Didn't know that a FPR or our fuel pumps could put out 80psi.
Old Jun 18, 2010 | 10:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If the reg or return line is not allowing fuel back to tank, I could see 80 being possible.
Are you confident the gauge is good ?
Old Jun 18, 2010 | 11:36 AM
383vett's Avatar
383vett
Double check the gauge. I would think the car would be running pig rich if the fuel pressure was that high. Especially in open loop.
Old Jun 18, 2010 | 12:37 PM
dogfish246's Avatar
dogfish246
with everything above, good info here!
Old Jun 21, 2010 | 06:09 PM
clambake0000
8th Gear
Thanks to all, I will double check the gage but I don`t think thats it as the gage is a high quality ss liquid filled test gage, when I first started to test with the original pump the gage read 10psi consistently.
Can you tell me if there are any other pressure controls in this fuel sys.?
Thanks again
Old Jun 21, 2010 | 07:56 PM
dogfish246's Avatar
dogfish246
Thanks again
There can also be a clog in your return line which could cause high fuel pressure even if the FPR is working properly... Is your fuel pump original?.
Old Jun 22, 2010 | 07:39 AM
clambake0000
8th Gear
Hi Thanks for getting back to me.
I believe that the one that failed (would only put out 10 psi) was the original one. I now know that it is not the gage as I put the press. regulator back togeather last night and at the risk of the new pump I ran it for a while and the press. went to 80 psi + and after about 20 seconds, in one abrupt move it dropped to aprox. 42 psi and I could hear the regulator dump the press. but then it climbed back to the 80 range. I blue air thru the returne line the first day and it is clear. When the regulator dumped the press. Some fuel did come out of the returne line.
The local automotive store has a kit for the regulator, I think I will buy that next. The original regulator looks good inside no leaking out the vent or tears in the diaphrame.
Thanks again.
Old Jun 22, 2010 | 08:51 AM
Sinister87's Avatar
Sinister87
I had this same problem on my 87 vette after putting in a new sending unit, I blew the line return line out with air and heard it bubbling in the tank, I rebuilt my FPR and swapped out to a different fuel rail gauge, which no of the above corrected the problem. I finally talked to Jim @ TPIS and he told me to check the return line at the fuel tank, sure enough the line had got kinked enough to restrict the fuel flow returning to the tank to cause a high pressure. A quick tug and pull and a zip tie to keep things in placed corrected the problem. Hope this helps
Old Dec 14, 2010 | 08:58 PM
Shawn624's Avatar
Shawn624
My fuel pressure was reading 80PSI. This thread led me to put the return line into a fuel can near the rail and power up the fuel pump (ignition on/not running). The pressure dropped to 47PSI. I looked closely at the return line and way back by the rear fender well the line was completely closed off (probably by a careless jack).
Thanks for the lead guys. This was a really frustrating one and I'm finally back in business.
To High Fuel pressure
