I know code 32 is a EGR trouble code I have changed out the EGR valve installed a new EGR Solonoid new plug and still getting the Code 32.
I been thinking could it be a pluged Intake EGR passage.
If I have to pull the intake to clean the intake I mite as well put a better intake on while I at it.
And here we go If I put some Summit Aluminun head on at the same time and replace my stok Iron heads on my 86.
And a set of Stamped 1.6 roller tip rockes.
Will this be worth doing, and how much gain will I get.
I was thinking about swaping the motor out but after doing a Compression check is good even across the board.
Good oil pressure No over heating Issues.
Will i have to mess with the computer chip.
The motor has 148000 miles on it.
I have read these motors can get 300000 miles out of them it's a street car not raced.
So what would be best just do the Intake , Intake, Head and Rockers.
No matter what I have to change the oil coolent, replace most of the same gaskets Ect.
I get the same code about once a week untill I turn the car off then it's gone for a week or so.
I will be replacing my EGR soon.
I checked everything including the egr solinoid so EGR is next to be replaced
