New shocks question?
Old Jul 1, 2010 | 01:02 PM
mundo's Avatar
mundo
Default New shocks question?
2 questions:
1. Anyone have experience with Gabriel Guardian shocks. I called Gabriel and they suggested the Guardian. He said the one for the Corvette is designed for the Corvette and will give back shock absorption without loosing ride control. They are $17.00 a piece through Autozone. About $75.00 out the door for 4 shocks - not bad. A set of KYB are nearly $200.
2. I'm wondering how BMW does it? Their sedans like 325 to 330 corner like no tomorrow on low profile tires like a Corvette. I rode in one and man the ride was smooth. What shock do they use. Remember they have to appeal to housewives and performance people. A housewife is not going to put up with a ride like a truck.
I'm trying to find that balance between a decent ride. Your teeth don't rattle or the whole car shifts when you hit a bump and decent performance such as no lean plus a reasonable price.
Old Jul 1, 2010 | 02:14 PM
CAJUN C4's Avatar
CAJUN C4
Couldn't find any Reviews on the Gaurdians. If I were you,I'd get a set of Low Mileage Bistiens.They virtually last forever.Some reports over 200K Miles and still within factory Specs.
What year do you have ?
Old Jul 1, 2010 | 04:02 PM
darkstallion_69's Avatar
darkstallion_69
Do not I repeat do not by anything Gabriel or Monroe. I have Gabriel Ultras which are supposed to be better than the Guardians.....$110 all 4. One word... CRAP! I had the original Bilstiens with 140,000 miles on them and they were beyond shot. When I put the new Gabriels on the car improved not as much as I wanted though. After 6000 miles they are already crapping out on me. The front is getting soft and the rear has too much rebound. I have not tried the KYBs on a vette.. I had them on a Foxbody Mustang 5.0 and they sucked. Went with Tokico after that. My next choice for my vette will be Bilstien or Tokico. Spend the money the first time cause if you dont you wont be happy and are going to want to buy shocks again like I do.
Old Jul 1, 2010 | 04:10 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
But as the OP has been rattled to death by bad roads and such, maybe he should give some of these a try.
For less than a C note he can give us a first hand comparison and maybe some CF'rs may benefit.
Old Jul 1, 2010 | 04:50 PM
CAJUN C4's Avatar
CAJUN C4
BMW's come from factory with Bilsteins just like our Vettes.That's why they ride/handle so good.
Old Jul 1, 2010 | 09:44 PM
JrRifleCoach
BMW spends much more time working with spring rates and shock valving to get the ride quality and handling. It took the big 3 fifty years to finally figure out how to design a car for the public. Instead of simply designing a car........
Old Jul 1, 2010 | 10:13 PM
Muffin's Avatar
Muffin
My 85 had some standard shock on it when I bought it, all were trashed. Got a deal on a set of Monroes. Six months and they were trash. Traded them in on a set of KYB's and haven't looked back. Before you ask, no I don't race, AutoX only cruise.
Old Jul 2, 2010 | 12:09 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I agree. I put some on my Silverado when it had 80k on it, and the stock shocks were getting worn. Right away, the ride was worse. Within 20k more miles, the Gabriels, one was seized solid and the other was completely blown out. Completely. The truck both SLAMMED over bumps...and undulated uncontrollably. They are garbage, and not worth the $17.00 price that you found. Keep looking.
I used monroe (junk), KYB's, Bilsteins and Koni's on my F-bodies. The Koni's were hands DOWN, the best. They are worth the money (on an F-Bod). Haven't tried them on a Y body yet.
BMW's also drive and ride well because they have a very solid, rigid, structure. C4's do not.
Old Jul 2, 2010 | 06:57 AM
TJM's Avatar
TJM
Originally Posted by mundo
2 questions:
Welcome to the C4 Forum!!!!! Nice C5 you got there....
Buy Bilsteins.
Call Randy at Doug Rippie Motor Sports [DRM], he is a supporting memeber and you can trust him.
TJM
Old Jul 2, 2010 | 11:32 AM
GKK's Avatar
GKK
BMW uses Coil Springs on all four corners which perform differently than a Transverse Leaf spring setup the Vette's use.
Maybe, you'll be satisfied with a Coil Over setup.
Old Jul 2, 2010 | 12:46 PM
mundo's Avatar
mundo
Originally Posted by TJM
Welcome to the C4 Forum!!!!! Nice C5 you got there....TJM
Thanks TJM. My C5 is beautiful in and out with a ZO6 engine and performance. When I'm done with this C4 I just picked up it will be just as beautiful with very good performance. Right now I'm just learning about second Gen C4s (1992 - 1996). I had an '84 which I made beautiful and almost 300 HP but did research on the Crossfire Forum.
Old Jul 2, 2010 | 01:29 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The type of spring used isn't what's causing the symptom that the OP is talking about. The C6 has very good ride quality and also uses transverse monoleaf springs. They TYPE of spring isn't the problem.
Old Jul 2, 2010 | 03:29 PM
mundo's Avatar
mundo
On certain types of bumps I actually have car hop instead of tire hop.
Old Jul 2, 2010 | 09:40 PM
GKK's Avatar
GKK
That's the nature of the Transverse Leaf spring, It acts like a sway bar which is desirable in auto crossing.
When going to work, I travel over a freeway expansion joint on a banked curve going about 65 mph and when I hit the expansion joint, my "91" Vette feels like the rear end hops and skips over the expansion joint which is kind of scary if you don't have both hands on the steering wheel.
Driving my wifes "07" Jetta over the same banked freeway expansion joint has no effect on ride quality.
So, I think Coil spring and Leaf spring designed vehicles do differ in the quality and type of ride you prefer.
Old Jul 3, 2010 | 04:25 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
NO! Please explain how the C5 and C6 manage to handle the same type bumps, with aplomb...when they're equipped w/Transverse leaf springs.
It's not the TYPE of spring. The C4 is not condemned to ride poorly b/c of the TYPE of spring used. If it were, the later Corvettes would ride the same. And they don't.
Youre logic is like saying that the Jetta is a 4 door, and the Corvette is a 2 door, so the Jetta Rides better over those joints because it's a 4 door. Obviously that's not true. The jetta rides better over expansion joints because:
It has a much stiffer, stronger frame
It has struts, which places the spring loads all the way out above the lower ball joint
It has less unsprung weight (smaller wheel/tire/brake package)
Better matched springs and shocks.
NOT because it's a 4 door....or because it has coil springs.
Old Jul 3, 2010 | 05:49 PM
Rob31's Avatar
Rob31
Old Jul 3, 2010 | 06:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Is no one reading my posts?
To New shocks question?
Old Jul 4, 2010 | 02:34 AM
GKK's Avatar
GKK
Here's a quote from "mundo" in a recent thread he started,
"The worst thing I ever did was put Bilstien shocks on my C5. The C5 had a decent ride but I knew the shocks were bad. So on went the Bilsteins. Now it rides like a pickup truck."
So, the C5 does seem to have a similar ride quality as the C4 with the similar Transverse leaf spring and Bilstein shocks, confirmed by mundos' experience with owning both generation Vette's.
To answer the OPs' original question, for the best balance between ride quality, performance and price I'd go with Tokico HP shocks. http://search.corvetteguys.com/?quer...&go.x=0&go.y=0
Old Jul 4, 2010 | 03:13 AM
mike100's Avatar
mike100
$17 Gabriels sounds like they aren't even gas charged. The Monroe sensa-tracs are also going to be too soft (I have some 6 month old ones with a lifetime reciept if you want them for free, I can arrange that if I have something else to hang on my car), but common wisdom says that the KYB shocks for a C4 are the minimum buy in because they offer a level of damping that isn't an embarrassment to the car's capability.
That said, the softer spring rate of the 94-96 base suspension works ok with softer shocks and good tires. They don't skip out as much over rough roads with a good tire. The whole suspension feels 'wiggly' with the softness and the chassis flex, but it still goes where you want it to.
It is certainly cushy with standard shocks though- you might like it.
Old Jul 4, 2010 | 03:23 AM
darkstallion_69
i have a 94 with the base suspension and crappy gabriel shocks and yeah the ride is soft and whatever. But i feel like im driving a regular car. on the highway its ridiculous. I want the stiffest shocks out there! plus there is no way this car will ride as bad as my foxbody stang it was almost riding on the bumpstops.
