MAF cleaner
Old Jul 1, 2010 | 07:57 PM
GS023's Avatar
GS023
Default MAF cleaner
Any one know if it's OK to use spray carb cleaner on the inside of a 96 MAF? Screen is removed.
Old Jul 1, 2010 | 08:14 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I wouldn't. Per my builder's observations (and mine since he mentioned it), carb cleaner leaves a residue. Brake cleaner is the better choice as a general engine parts cleaner.
That said, there's a relay that superheats the wire (aka burnoff relay). I don't see how a cleaner is going to improve on that.
Old Jul 2, 2010 | 01:39 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
There are cleaners available specifically for the MAF. I'd go with the recommended product.
Old Jul 2, 2010 | 02:46 AM
chileverde's Avatar
chileverde
just use a qtip to wipe down the wires.
Old Jul 2, 2010 | 07:28 AM
pcolt94's Avatar
pcolt94
I don’t believe the 96 uses a burn off relay or that system as the earlier vetts.
Although sounds like a plan, would not want or leave any fibers behind or even worse break one of the wires. It could turn out to be a costly mess when you just wanted to do a cleaning and make it better.
Old Jul 2, 2010 | 09:48 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
NO-NO-NO
________________________________________ _________________________
Use MAF Cleaner and read the can's directions.
Old Jul 2, 2010 | 09:49 AM
chileverde's Avatar
chileverde
i did do the q-tip thing and it cleaned up nice, just a little care was needed to keep it from leaving fibers or breaking a wire.
Old Jul 2, 2010 | 09:54 AM
Muffin's Avatar
Muffin
Not a good idea. Those wires are something like 1/4 the diameter of a human hair and have been subject to a kazillion heat cycles. I don't think touching them would be a good idea. I am even afraid of the MAF cleaners, but I always err on the safe side.
I read that 1/4 thing somewhere, don't know is they are that small or not.
Old Jul 2, 2010 | 10:12 AM
chileverde's Avatar
chileverde
i just hate spraying caustic stuff if i don't have to. heck i even use a q-tip to clean off my armpit hairs one at a time instead of cancer causing deodorants.
ok i made that last line up - lol.
i suppose i'd break down and use the cleaner if the maf was off the car - i'm usually not a big fan of putting cleaners into the intake tract.
Old Jul 2, 2010 | 11:16 AM
JAKE's Avatar
JAKE
CRC makes a specifc spray product for cleaning MAF.
Up until posts in this thread, the universal recommendation was NEVER TOUCH THE MAF WIRES, to which is still STRONGLY advise.
Jake
Old Jul 2, 2010 | 12:36 PM
aboatguy's Avatar
aboatguy
Originally Posted by PLRX
NO-NO-NO
Jake
CRC MAF cleaner is readily available and easy enough to use...
Old Jul 2, 2010 | 03:55 PM
chileverde's Avatar
chileverde
not only does it clean but it adds 10hp just for using their brand!
Old Jul 2, 2010 | 04:23 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
So you guys are saying I shouldn't have cleaned my MAF by throwing it in the dishwasher? DOH!
Old Jul 2, 2010 | 06:15 PM
floridamale's Avatar
floridamale
You should be OK if you used the sterilization cycle, but remember to bake it after in the oven afterwards
To MAF cleaner
