Problems with my new engine
Here is link to more details:
http://forums.corvetteforum.com/c4-t...e-project.html
In short here are engine specs
- 2bolt block, overbored 0.020"
- stock crank
- SCAT forged rods 5.7"
- SRP forged pistons, flat-top
- #113 heads, ported, 2.02/1.60 valves
- ported superram
- #24 FMS injectors
- Hooker LT headers
- CC XR288HR cam, 288/294 adv., 236/242 @.050", .55"/.57" lift, 110 LSA
I'm having my tune done by Mick (mseven). Engine fired right up with
his first tune but it was running rough and very rich.
From datalogs, we have noticed that vacuum is low (70+ kPa). So I tried to find if there are any vacuum leaks or other mechanical problems. I did find some issues, but I sorted them out and I still have the same problems.
Problems are next:
When I start the engine it runs stable but very rich. WBO2 is showing high 11 to low 12AFR and considering the size of the cam
and overlap, I think that it's even more rich than that.
As the engine is heating up the problems start. Engine wants to stall and sometimes it stalls if I don't blip a throttle.
Idle starts to go up and down all the time.
IAC ccounts are allways going down. From the moment when I start the engine IAC counts are slowly going down, until
they finally reach zero. If I adjust the throttle screw I can get them to raise, but again, as the engine is running IAC starts to drop.
Map signal is acting very similar. As I start the engine, it's stable at lower 70's but as the problems with stalling start, MAP starts
to jump all over the place. I guess that it's normal that it jumps to 90 because engine almost stalls.
All the time there is way too much fuel as I can see it smoke and it really burns the eyes.
As for vacuums, I have plugged everything except MAP, fuel regulator and PCV hoses.
I have tried to plug the TB with engine running and listen for any vacuum leaks but I can't hear anything.
Any inputs and ideas are welcome!
I'd invest in a little tuning equipment because tuning by mail is never gonna be technically correct and problems like this become long term versus very quickly solved. I understand that once you have a bunch of setups tuned and saved that you can pretty much get close via mail, but each setup is still unique in it's own way and tuning the car itself is still gonna be the preferred method.
