Need help with VATS
Old Jul 4, 2010 | 07:31 AM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
Default Need help with VATS
I guess it's the VATS system that's giving me problem. Drove our 89 Vette to and from work one day, shut it off, and tried to go somewhere 15 minutes later only to have absolutly no response from the starter.
Tried our other key to no avail. Bought a vats system bypass and still nothing. Also tried a new starter relay still nothing at all. Anyone have any ideas.
Bert
Old Jul 4, 2010 | 07:35 AM
Valley Boy's Avatar
Valley Boy
Did you check the "Security" fuse? It's a 15-amp in the fusebox located on the passenger side of the dash. You can swap it with the courtesy lamp fuse if you need to...
Old Jul 4, 2010 | 07:45 AM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
Yes the fuse is okay!
Old Jul 4, 2010 | 07:57 AM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
At this point we are thinking of just trying to sell it for wahtever we can, but don't know how much to ask for it. It has less than 50,000 miles and my wife just loves her summer car.
Old Jul 4, 2010 | 08:49 AM
Jamesnns's Avatar
Jamesnns
Codes?
Try cleaning your key pellett.
Good batt?
edit
Any chance you had a dirty key, then tried your 2nd key, which MAY have been wrong, ordered a improper VATS bypass off of dirty or wrong key?
Could happen.
You can see your key reistance using the paperclip method, this will tell you if your CCM is reading a diff. between keys.
Old Jul 4, 2010 | 08:54 AM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
Originally Posted by Jamesnns
Codes?
Good batt?
battery good! Tried both keys and a VATS bypass.
Old Jul 4, 2010 | 09:05 AM
Jamesnns's Avatar
Jamesnns
Using the paperclip method, here's how to retrieve your key pellet info. I'd check to make sure your getting the same value from each key pellet.
http://forums.corvetteforum.com/c4-t...n-96-cars.html
Go to Module 1.2-6
You'll get a 3 digit number, this correlates to a passkey number (1-15)
Both numbers should match from each key
XXX Value = Key code number
33-38 #1
42-47 #2
52-58 #3
64-70 #4
76-83 #5
91-98 #6
106-113 #7
121-128 #8
136-143 #9
149-156 #10
164-170 #11
177-183 #12
188-194 #13
199-204 #14
208-213 #15
Old Jul 4, 2010 | 09:20 AM
hooked073's Avatar
hooked073
did you check starter? have someone hold key to crank and see if you have 12volts on the s terminal. if you do and it does not crank it is starter. You can always try this have someone turn the key and tap on the starter with a hammer. But before this check battery connections, Battery. Do you have power to anythng?
Old Jul 4, 2010 | 09:23 AM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
Go to Module 1.2-6
33-38 #1
42-47 #2
52-58 #3
64-70 #4
76-83 #5
91-98 #6
106-113 #7
121-128 #8
136-143 #9
149-156 #10
164-170 #11
177-183 #12
188-194 #13
199-204 #14
208-213 #15
I read both keys and came up with same value (1080) which is #7 key. When I purchased the VATS bypass, I also cheked this and got the same reading. If I hook up a code detector will this give me any information?
Old Jul 4, 2010 | 09:28 AM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
At one point I shorted out the starter relay while holding the key switch to the start position. I got the car to start, but the fuel injection was not working right and filled the exhaust with unburned fuel. NOT A GOOD EXPERIENCE>
Old Jul 4, 2010 | 10:18 AM
hooked073's Avatar
hooked073
is the car automatic or standard?
Old Jul 4, 2010 | 11:11 AM
skybolt31's Avatar
skybolt31
I hate to sound critical, but this is an easy problem to troubleshoot. Start at the starter, is there power there when you turn the key to start, if yes, then the problem is the starter, if not you need to go back to the next step which I believe from memory is the clutch switch or neutral safety switch. If you look in the FSM, it will show you how the power gets from the battery to the starter, trace it back and see where your problem is and then replace the appropriate part.
Old Jul 4, 2010 | 12:23 PM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
Automatic
Old Jul 4, 2010 | 12:41 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
This problem will be easy to fix very difficult to guess correctly.
Old Jul 4, 2010 | 01:40 PM
hooked073's Avatar
hooked073
Badduck and Skybolt are correct. That is where I was going in my frist post the reason I asked if it was auto or not was if things checked out from my first post. Then to check and see if you have power at the neutral safety, if you do jump across it and see what happens.
Old Jul 4, 2010 | 02:16 PM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
Let me tell you that I don't even hear the fuel pump. My gauges work, but that's all the response I get when I turn on the key. I have been told that the problem is with the security system and that the Vats is somehow causing the problem.
I DON'T KNOW AND AT MY WITS END.
Old Jul 4, 2010 | 03:06 PM
Jamesnns's Avatar
Jamesnns
Take it to a comp. mechanic and.............
Skybolt31 said...
A good mechanic will get you done in no time.
or...
89, red, vert, -50K miles..."At this point we are thinking of just trying to sell it for whatever we can, but don't know how much to ask for it"
How much?
Just take it in......
To Need help with VATS
Old Jul 4, 2010 | 11:14 PM
jfb's Avatar
jfb
Can you hear the starter solenoid click? Did you remove the battery cables and clean the cable lugs, bolts and battery terminals? VATS has nothing to do with the fuel pump. If you can't hear the starter solenoid click, then you may have VATS problems. Use the search function for VATS, I have typed how to trouble shoot VATS over 300 times.
Old Jul 4, 2010 | 11:15 PM
jfb's Avatar
jfb
Ask and I will type it again.
Old Jul 5, 2010 | 07:10 AM
Bert&Cindy's Avatar
Bert&Cindy
Cruising
Skybolt31 said...
or...
How much?
Have a neighbor that's a mechanic. Going to ask him to take a look at it if he can. Don't know how he'll get it to his garage(to low to the ground). Probably will have to sell it to pay the bill!
The car is listed as a classic and could be sold for 15,000 if in excellent condition. At this point it is definatly not in excellant condition. Probably going to ask 10,000 or best offer. What do you think?
