getting started
Old Jul 8, 2010 | 05:59 AM
nate65's Avatar
nate65
4th Gear
Default getting started
car starts but will not idle.what are some sugestions on what is wrong.
Old Jul 8, 2010 | 06:26 AM
ChrisLT1conv's Avatar
ChrisLT1conv
any codes? how about o2 sensor. If one goes bad car idles horribly
Old Jul 8, 2010 | 06:57 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
1. Loose or faulty electrical connections at distributor, coil or alternator
2. Insufficient fuel reaching the fuel injectors
3. Vacuum leak at the gasket between the intake manifold and throttle body
Old Jul 8, 2010 | 09:46 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You might want to start with the idle air control valve.
Diagnostics >>> http://members.shaw.ca/agent86/IAC%20Diagnosis.pdf
Then the throttle position sensor's idle voltage and minimum idle setting.
http://www.lbfun.com/warehouse/tech_...ch%20Paper.pdf
Is this a new problem or a new to you problem ?
Old Jul 9, 2010 | 12:02 AM
nate65's Avatar
nate65
4th Gear
The fuel pressure is 18psi but it does not hold pressure.car is hard to start.
Old Jul 9, 2010 | 07:29 AM
AGENT 86's Avatar
AGENT 86
18 PSI is not anywhere close to enough pressure to make her run. Is there any fuel in the regulator vacuum line ?
Fuel delivery diagnostics from 86 FSM
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
Old Jul 9, 2010 | 07:37 AM
floridamale's Avatar
floridamale
The good thing is you know what the trouble is, now you only have to find out what is causing it.
Old Jul 12, 2010 | 11:56 AM
nate65's Avatar
nate65
4th Gear
Default fuel pressure
What should the fuel pressure be . Replaced fuel pump and filters.
Old Jul 12, 2010 | 12:46 PM
walter schweigert's Avatar
walter schweigert
Approx 38-42 psi. based on what I have read in some other posts.
Old Jul 12, 2010 | 03:01 PM
nate65's Avatar
nate65
4th Gear
i bought the car a few months ago and it has been getting steadily worse
To getting started
