anyone know of a fix ?
Service light is on !
I have made a few mods including headers , installed my 02 sensor in the collector , don't think it is getting hot enough to work properly !
1990 L98
I have been searching , but the info I have gotten is for a 2 sensor system , I only have one
It isn't too difficult. You need the O2 sensor that has 3 or 4 wires.
3 wire sensor has 1 ground, 1 power and 1 feed. 4 wire sensor, the same except it has 2 grounds. The feed goes back to the same place (purple wire) and you hook up grounds and switched power. You don't need to buy both sensors. Done that recently
