Sealing the intake...
Old Jul 16, 2010 | 03:57 PM
Weav's Vet's Avatar
Weav's Vet
Default Sealing the intake...
Is it best to wait 24 hrs before cranking a motor with a intake that was just installed?
Old Jul 16, 2010 | 04:00 PM
Pwnage1337's Avatar
Pwnage1337
I think all you have to really wait for is the RTV to cure, and depends on the heat/humidity. I think RTV cures in 12 hours? Not sure.
Old Jul 16, 2010 | 04:04 PM
Weav's Vet's Avatar
Weav's Vet
Thanks, didn't use RTV. I used The Right Stuff which sets up in just a short time.
Someone told me it was best to wait to crank it. I was wondering what the general consensus was. I can't see how a gasket would seal any better if it sat for that long before being cranked.
Old Jul 16, 2010 | 04:14 PM
STL94LT1's Avatar
STL94LT1
The gasket will seal when torqued. Start-up should depend on the sealant cure time.
Old Jul 16, 2010 | 04:56 PM
Weav's Vet's Avatar
Weav's Vet
That's what I thought. I put the ported LT1 intake back on and it still acts like it's getting to much air from somewhere. This is about to get the best of me Mike.
Old Jul 16, 2010 | 05:08 PM
STL94LT1's Avatar
STL94LT1
Mike, you have a great running car. Once you get this intake situation solved why don't you take a step back and enjoy the fruit of your labors for a while. Just drive the car and try to quit overthinking the small details. The more your drive with the same combo the PCM will learn and some of the small tuning issues will go away.
Old Jul 16, 2010 | 05:13 PM
Weav's Vet's Avatar
Weav's Vet
I know.......it did run pretty good before I chanced these headers. Now it's like protesting or something
I broke a wire in the TPS plug so I'm waiting on a pigtail, it'll be here in the morning. I think I will drive it a while and just see what transpires after I get that fixed. thanks for the advice
Old Jul 16, 2010 | 05:30 PM
STL94LT1's Avatar
STL94LT1
Are you putting any sealant on the intake gasket, or installing dry? I read where some recommend smearing a small film of sealant on the gasket, to me this could cause a sealing problem by uneven sealant. I always install my LT1 intake gaskets dry and have never had a sealing problem.
Old Jul 16, 2010 | 05:39 PM
Weav's Vet's Avatar
Weav's Vet
I used some on the Edlebrock but it appears to have dissolved. Permatex Formagasket #2. These last two times with the LT1 was done dry.
I just checked the Edelbrock to see if it was straight where the port flanges are. NOT! There's a slight hump in the middle where the PCV grommet goes. The right side is flat. Not much but it's there. Maybe this one in there now is that way to. My old intake is very flat on both sides but not ported.
Old Jul 16, 2010 | 06:58 PM
LT4BUD's Avatar
LT4BUD
Actuallly it seems like what you did should be ok, but......Permatex appears to only recommend RTV Sealant 82180 for sealing of ends of intake manifolds, which is what GM & Edelbrock specify....."Right Stuff" does not list end seals on intake manifolds as an application
http://www.permatex.com/documents/Ga...erSelector.pdf
..appears there might be more of a difference than just curing times
Old Jul 16, 2010 | 07:55 PM
Weav's Vet's Avatar
Weav's Vet
But it is OEM specified, right? Guess it's that internet thing again....I read somewhere The Right Stuff was developed especially for GM by Permatex to seal intake applications because of so many leaks on the LT1. I'm not having an oil leak. I 'm having and intake port leak. Thanks though Great link!
Old Jul 16, 2010 | 09:51 PM
Pete K's Avatar
Pete K
Regardless of sealer brand, I do not fire a motor for a minimum 24 hours after torquing the manifold.
Old Jul 16, 2010 | 10:31 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I do the same. I dont know if it is really "required" but it gives me piece of mind.
Old Jul 16, 2010 | 11:01 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Last year when I installed the wrong intake gasket, I went back and disassembled the intake 3-4 days later and the RTV was not cured.
my 2 cents
Old Jul 17, 2010 | 12:17 AM
1985 Corvette's Avatar
1985 Corvette
Pete, check your pm box.
Old Jul 17, 2010 | 12:38 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I use the Right Stuff too. One time I did need to fire the motor within about 4 hours of bolting the intake on because I had to get it out of the garage. Everything was fine. I didn't let it run long but it sealed and ran fine until the day I tore it apart.
Old Jul 17, 2010 | 07:33 PM
Weav's Vet's Avatar
Weav's Vet
I fired it up today and sprayed carb cleaner around the entire intake and no change in rpm. If it's leaking it's in the lifter valley. Idle is decent so I doubt that is happening. Sitting overnight seems to have helped it.
Thanks for all the responses guys.
Old Jul 18, 2010 | 03:14 PM
JAKE's Avatar
JAKE
I fire my engines as soon as I finish bolting everything back together. I've never let it sit for 24 hours or any other length of time.
Another point, I always install the intake BEFORE the sensor safe silicone sealant skins over. I want it to still be wet in order to fill in nicks, etc. as it's compressed.
One more, I always apply a thin layer of sealant on BOTH SIDES of the intake gaskets. Pressure from the 35 lb/ft of bolt torque flattens it out. This is shown in one of the Chevy build manuals I have.
And again, I go over my intake manifold bolts numerous times until they all HOLD the torque setting. This may take hours while the gaskets take a compression set.
Lastly, I use a 3/8" bead on each China Wall, as opposed to the 1/4" bead often cited. I also dimple the China Wall areas on BOTH the block and the underside of the intake. ShoeBox - a guru on some other Forums (but, alas, not here) - does that too. "Old Racer's" stuff; and since I'm an "OLD Racer", well, there you go.
I post a detailed STICKY on LS1LT1.Com on the LT1 TECH board for those who like to read. My stuff doesn't leak - I don't play that, LOL
Jake
To Sealing the intake...
