86 irregular idle
Old Jul 18, 2010 | 10:03 AM
jdenn47's Avatar
jdenn47
Default 86 irregular idle
I have an 86 and the engine has been missing at idle and while driving at a constant speed. Check engine on light showed MAF issue. Replaced MAF, still missing. Replaced plugs and wires. Still missing but not as bad. Idle speed varies.
Any ideas as engine has over 103K on it. Also on another note, when driving a while and engine hot, tends to not start when trying to start it soon afterward, only clicks for a few times. Then starts up OK.
Thanks,
JD
Old Jul 18, 2010 | 10:51 AM
megtom2's Avatar
megtom2
Thanks,
JD
Hello fellow 86er. Our 86 had a whacky idle when we bought it last year with 92k on it. I changed the fuel filter and O2 sensor and it took care of the 6k to 8k surge at idle.
If you have a fuel pressure gauge hook it up and see what pressure you are getting when the car is idling. Should be somewhere around 43 and steady.
Old Jul 18, 2010 | 10:56 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I have an 86. The missing can be due to a bunch of things.
1. The first thing is plugs and wires.
2. could be a cracked dist. cap
3. a bad injector
4. The wire on the dist. cap is not tight or has corrosion on the metal tang.
5. bad coil. gets hot and shorts intermittantly.
as for the starting, my starter just wore out. It would start up cold, and I'd get to the market, buy milk or whatever, get back out to the car, and no start. happened 3 times.
I took the starter apart, cleaned up the commutator, and replaced the brushes and solenoid, and it's been in there 3 years without a problem.
It;s a bear to get out, but well worth it if you don't have to walk in summer heat.
Also, right above the starter is the wire harness. Don't mess with it trying to push it out of the way. The plastic vacuum lines are in the harness, and if you push it out of the way, you break the vacuum line, and you have to unwrap it and put new vacuum lines in that connector. What a bear!!!!If you break it, your heater will not shut off.
Old Jul 18, 2010 | 11:01 AM
megtom2's Avatar
megtom2
3. a bad injector
:Note to self: If the starter on our 86 ever acts up take it to a shop to work on. I hope I remember that one. lol
Old Jul 27, 2010 | 01:46 PM
jdenn47's Avatar
jdenn47
Replaced Plugs, wires and fuel filter. (All needed replacement soon)
Still rough idle and when you open the throtle, it hesitates for a sec.
Could it be injectors? Cleaned at 82K, now has 104K.
Air filter is a K&N, cleaned recently.
Old Jul 27, 2010 | 01:52 PM
pmihaltian's Avatar
pmihaltian
Slingshot
What exactly was the code ? Was it Code 33 ? Let us know.
Old Jul 28, 2010 | 02:43 PM
jdenn47's Avatar
jdenn47
After replacing the MAF, check engine light went off. Mechanic said it was the MAF that needed replacing. I believe the code was 33.
Old Jul 31, 2010 | 10:37 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Yes, Code 33 indicates Mass Air Sensor problems.
Old Jul 31, 2010 | 03:55 PM
jdenn47's Avatar
jdenn47
Could the rough ideling be caused by a bad O2 sensor or TPS system issue?
I have no check engine lights on anymore.
I have been told that it is possible that the coil or dist. cap could be the problem which would also cause hard starting. Any thoughts ?
Old Sep 9, 2010 | 03:23 PM
jdenn47's Avatar
jdenn47
Replaced Dist. and Rotor. Still runs idles rough and run rough.
Engine service soon light comes on sometimes when started and then stays off when started another time. Can the MAF, which is new, be causing the whole problem? Or can this possibly be a fule presure reg. or pump problem?
Old Sep 9, 2010 | 04:53 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Do a fuel pressure test
Old Sep 9, 2010 | 05:50 PM
tehcarguy's Avatar
tehcarguy
Unplug the MAF, start it and see if the idle smooths out. I just had some idling issues on my 86, and it was the IAC. And, as RetiredSFC said, do a fuel pressure test at the shrader valve.
Old Sep 9, 2010 | 06:36 PM
RetiredSFC 97
And ohm those injectors
Old Sep 10, 2010 | 01:31 AM
coupeguy2001
I hope you didn't screw the idle screw in or out. There is a procedure to adjust it. If it is at one end or the other of it's travel, the IAC cannot compensate for various things.
Old Sep 10, 2010 | 12:17 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
And get thee a Factory Service Manual (FSM).
Old Sep 10, 2010 | 12:52 PM
avgjoe's Avatar
avgjoe
My 88 had a similar problem. It was the O2 sensor although I believe it threw a code.
To 86 irregular idle
