No fuel !
Old Jul 18, 2010 | 08:31 PM
sweets's Avatar
sweets
Default No fuel !
im stuck in my driveway.what sencer or relay shuts of the injectors?i have fuel pressure but car wont start. it started out like a miss , bad plug. now it wont start at all.i poured some gas into the plennum and stuck the intake hose back on and it ran but stoped like it was running out of gas. help...............
Old Jul 18, 2010 | 08:52 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
What year vette?
With limited info..fuel filter? Plugged injectors?
Old Jul 18, 2010 | 08:54 PM
sweets's Avatar
sweets
its an 89
Old Jul 18, 2010 | 08:59 PM
sweets's Avatar
sweets
it sounds like aw3375 has the same problem..............
Old Jul 19, 2010 | 08:59 AM
WW7's Avatar
WW7
its an 89
Im with Corvette Mike on the possible causes,and I would give a real hard look at the injectors. 89s have known problems with the stock injectors ...Start by doing a ohm test on them , they should be somewhere near 16 ohm....WW
Old Jul 19, 2010 | 09:19 AM
sweets's Avatar
sweets
i did that test last week. i replaced the injectors 5 years ago .i used accell from summitt. how can i check the pulse while cranking the motor over?
Old Jul 19, 2010 | 09:29 AM
86reddriver's Avatar
86reddriver
7th Gear
Go to Auto Zone and buy/borrow their "Noid light kit" for $25, and it has a set of LEDs that you plug into your injector wire to check for a pulse. I did it yesterday (see "Now won't start" thread). I get no pulse on any of the ones iI tried it on, but no-one has said what to do now. We may have the same problem.
Old Jul 19, 2010 | 09:43 AM
sweets's Avatar
sweets
i will do that tonight. i know a gm tech and i will call him today. i know that my 98 chevy truck had a way to shut of the inj. when oil pressure was lost,so im woundering if the 89 vette has the same.
Old Jul 19, 2010 | 10:03 AM
86reddriver
7th Gear
I have oil pressure while cranking , but still no injector pulses, so oil pressure isn't the problem (at least in my case).
To No fuel !
