why am i running hot
Old Jul 30, 2010 | 11:13 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Originally Posted by BADDUCK
I don't think fans are your problem. If you are running both fans all the time.
You have water or air flow blockage somewhere.
With both fans running and a properly operating cooling system, your temps should never get above 225.
Old Jul 30, 2010 | 11:16 PM
94roseman's Avatar
94roseman
i also agree thats why i asked for help lol.
i used gasket only not sealant on the waterpump.
Old Aug 4, 2010 | 06:15 PM
Chad McCan's Avatar
Chad McCan
I'm in the same boat. I have a 94 coupe. I put a water pump on it the day I bought it, 2 years ago. It's been hot this week, 101 yesterday. The car will melt itself down (240+) with the air on after a 35 minute drive. It climbs a degree or two at a time. When it overheats, it spews coolant out of the radiator cap.
I drove home today (90 degrees outside) with the air off. It never reached more than 205 (30 minute drive on the highway). As soon as I get off the highway, the temp starts to climib. 5 minutes off the highway and it's 230+. I'm guessing that's because they fans don't kick on until 229.
I'm resigned to just saying I can't drive my car, in this heat, with the air on.
Old Aug 4, 2010 | 06:30 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by James93LT1
Just a fyi, my car usually runs between 176 to 200 with the 160 themostat.
You might want to double check your thermostat, when doing your radiator.
and make sure it is for an LT1.
Old Aug 4, 2010 | 06:36 PM
CAJUN C4's Avatar
CAJUN C4
Definatly...You have a blockage somewhere..might get the radiator rodded out.Today in 106F corrected Temp. with A/C on and a 65 mile trip at 70 MPH the temp never got above 182F.(I have a 160 TS) has to be blockage..the fans don't even run at 70 MPH anyway.
Old Aug 4, 2010 | 07:29 PM
pantera1683's Avatar
pantera1683
Don't the fans run when the AC is on regardless of temperature?
Old Aug 4, 2010 | 07:33 PM
CAJUN C4's Avatar
CAJUN C4
Yes they do...But at Speed I believe the incoming air is such that the Fans are turned off...I Think.....Somebody help me with this one.
Old Aug 4, 2010 | 07:55 PM
mike c4's Avatar
mike c4
Originally Posted by chad mccan
i'm in the same boat. I have a 94 coupe. I put a water pump on it the day i bought it, 2 years ago. It's been hot this week, 101 yesterday. The car will melt itself down (240+) with the air on after a 35 minute drive. It climbs a degree or two at a time. When it overheats, it spews coolant out of the radiator cap.
I drove home today (90 degrees outside) with the air off. It never reached more than 205 (30 minute drive on the highway). As soon as i get off the highway, the temp starts to climib. 5 minutes off the highway and it's 230+. I'm guessing that's because they fans don't kick on until 229.
I'm resigned to just saying i can't drive my car, in this heat, with the air on.
i know this may have been done already but have you put on a new rad cap of the correct pressure sometimes we overlook sinple things
Old Aug 4, 2010 | 09:55 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I didnt read all the posts but, here are my 2 cents.
I have all new mods for cooling the LT engines. I went to Vegas a month ago, it was 107 F, got stuck in traffic and the temp went up to 235 F. I turned the heat on and the temp went down to 216 F.
Its summer, its hot and unless you are driving above 40 MPH the fans only give you the equivalent to 6-10 MPH winds.
Old Aug 4, 2010 | 10:41 PM
rlf105's Avatar
rlf105
you mentioned a cam swap; have you checked youre timing? If too far advanced it can cause a car to heat up. Just 1 more thing to consider
Old Aug 5, 2010 | 10:50 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
DING DING DING!!! you PRESSURE WASHED THE CONDENSER?
you bent over all the fins on the condenser!!!!
look at the condenser with a mirror and a flashlight and or drop a light on the back side of the radiator and stick your head up in the air intake just behind the bumper, and see if you see any light. I bet you blocked your air flow just like closing venetian blinds or shutters.
sounds like it's time for a new condenser...................
Old Aug 5, 2010 | 11:02 AM
1911fool's Avatar
1911fool
I was going to post the same thing.
Old Aug 5, 2010 | 05:21 PM
  #33
94roseman's Avatar
94roseman
Well my problem is fixed...i replaced, fans-radiator-coolant cap-160 thermostat.
i check the ac condencer and the fins looked fine, and the car was tuned by pcmforless so i dont know about the timing. oh and my thermostat is for regular sbc not the lt1, nobody in town had one for atleast 3days.
I also have both fans set up on a key on swtich so that the run when the key is on.
today was 94degree, i sat in trafic with ac on for like 20 and car never got over 225.
Old Aug 5, 2010 | 05:23 PM
  #34
94roseman's Avatar
94roseman
oh and bleeding the system is a big part...i just carried a screw driver with me and started driving...pulled over every few miles and turned on the bleeder screws. this of course was ildleing and burping it for like 30 min in the driveway.
Old Aug 5, 2010 | 06:50 PM
  #35
Chad McCan's Avatar
Chad McCan
My car is black. I'm beginning to think that is playing a part in it.
Old Aug 6, 2010 | 08:53 PM
  #36
STL94LT1's Avatar
STL94LT1
You need to get an LT1 specific thermostat. The LT1 has a reverse flow coolant system and the SBC thermostat will not work properly in your car.
