Flashing security light (vats)
Old Aug 30, 2010 | 06:10 PM
Steve_Sanders's Avatar
Steve_Sanders
Default Flashing security light (vats)
My cars security light flashes and will not start. It continues flashing even when the car is off. The previous owner tried to diagnose this problem and failed. I found the vats box behind the bread box completely unplugged. I plugged it back in and the light started flashing. So I ordered a vats relay from mid america, plugged it in and still no start. The light just flashes. The car will crank and slightly fire up for a split second. Rail is getting fuel. Is there another procedure to plug this resistor in?
Mid america resistor reads 6.08 and my key reads 6.02
Old Aug 31, 2010 | 09:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If it's cranking, it's 99.9% not a VATS problem. The VATS module disables starter and injectors.
The Security light is for the Forced Entry Alarm (Theft Deterent Controller) and does not affect cranking or injectors.
Here is some info on both, should help you diagnose the Security light problem.
http://members.shaw.ca/dankai/Vats%20Electrical.pdf
Do you have a noid light to check for injector pulse ?
Old Aug 31, 2010 | 04:52 PM
Steve_Sanders
OK thanks for clearing that up. The car will sometimes start up for a split second. The rail is getting fuel but no I don't have the tool to see if the injectors are firing. One thing I did notice was the SES light never comes on. I pulled the DIC and switched the bulb with no change so the SES is not showing up at all. I'm thinking maybe the ECM is shot? I opened it up and there is a hypertech chip in it. It also says re manufactured. The guy who owned this car before tried diagnosing this thing and changed a bunch of stuff. There is a brown wire hanging out from the main wiring distribution that goes through the firewall on the drivers side. It is a very thin gauge brown wire and it is just hanging there with a cut end on it.
Old Aug 31, 2010 | 07:25 PM
AGENT 86's Avatar
AGENT 86
No SES light is never a good thing. Try and diagnose that first.
http://members.shaw.ca/corvette86/No...0-%20Light.pdf
Old Sep 19, 2010 | 01:16 PM
Steve_Sanders
Ok it turned out to be the ECM went and pulled one out of a S10, changed the prom and boom she fired up.
Old Nov 26, 2010 | 11:22 AM
me0917's Avatar
me0917
1st Gear
what year model s10 did you use the EMC from? my 93 vette is doing the same thing
Old Nov 26, 2010 | 04:31 PM
Steve_Sanders
Here is a reference for anyone looking for a replacement ECM and cannot find a parts vette or does not want to overpay.
1227165 (less PROM)
* 1987-90 Astro/Safari Van with 2.5L 4 cylinder
* 1987-88 Blazer S10/Jimmy S15 with 2.5L 4 cylinder
* 1991 BlazerS10/Jimmy S15 with 4.3L 6 cylinder (with 1227165 ECM)
* 1991 Bravada (with 1227165 ECM)
* 1987 Camaro/Firebird with 5.7L 8 cylinder
* 1988 Camaro/Firebird with 5.0L 8 cylinder with MFI
* 1988 Camaro/Firebird with 5.7L 8 cylinder
* 1986-87 Camaro/Firebird with 5.0L 8 cylinder with EFI
* 1989 Camaro/Firebird with 5.0L 8 cylinder with MFI
* 1986 Cavalier/Cimarron with 2.0L 4 cylinder and manual trans
* 1989 Camaro/Firebird with 5.7L 8 cylinder
* 1986 Firenza/Skyhawk/Sunbird with 2.0L 4 cylinder and manual trans
* 1986-89 Corvette
* 1987-91 S10/S15/Sonoma with 2.5L 4 cylinder
* 1991 S10/S15/Sonoma with 4.3L 6 cylinder (with 1227165 ECM)
1227730/16196344/16198262 (less PROM)
* 1987-89 6000/Beretta with 2.8L 6 cylinder
* 1989-91 6000/Beretta with 3.1L 6 cylinder
* 1987 Beretta/Cavalier/Corsica/Tempest
* 1988 Beretta/Corsica/Tempest with 2.0L 4 cylinder (thru VIN 500,000)
* 1990-92 Camaro/Firebird with 3.1L 6 cylinder
* 1990-92 Camaro/Firebird with 5.0L 8 cylinder with MFI
* 1990-92 Camaro/Firebird with 5.7L 8 cylinder
* 1988-89 Cavalier/Corsica/Tempest with 2.8L 6 cylinder
* 1990-93 Cavalier/Corsica with 3.1L 6 cylinder
* 1987-89 Celebrity/Ciera with 2.8L 6 cylinder
* 1990 Celebrity with 3.1L 6 cylinder
* 1987-88 Century with 2.8L 6 cylinder
* 1987-88 Cimarron
* 1987 Firenza with 2.0L 4 cylinder without OHC
* 1987 Firenza with 2.8L 6 cylinder
* 1987 Skyhawk with 2.0L 4 cylinder without Turbo, without OHC
* 1991-93 Sunbird with 3.1L 6 cylinder
* 1990-91 Tempest with 3.1L 6 cylinder
To Flashing security light (vats)
