new (to me) '86 with a starting problem
Old Aug 30, 2010 | 11:16 PM
Stan L's Avatar
Stan L
2nd Gear
Default new (to me) '86 with a starting problem
Hello all,
About a month ago, I purchased my first ever 'vette (and, interestingly enough, my first used car as well). Altogether, its been a great car, but in the last week or so I've been having some starting issues I was hoping somebody could help me with.
The car turns over fine, and then sort of starts (very low idle, around 400-500). It then promptly dies. This happens every time on a cold start (and quite a few hot starts as well) until it give it a bit of throttle when I turn the key. If I let go of the throttle before I get into gear, the car usually dies. However, as soon as I get into gear and start driving, the car has no problems.
My first thought was that the battery was running out of juice (and was running just off the alternator when i gave it some gas), but my multimeter shows 12.4v on the battery and the dash shows 12.3v, so I'm not so sure of that any more.
Any help would be greatly appreciated!
Old Aug 30, 2010 | 11:51 PM
JAKE's Avatar
JAKE
Can you hear the fuel pump energize to prime the fuel system when you turn the ignition key to "ON"?
If not I'd suspect the fuel pump relay.
If you hear it I'd suspect the Cold Start Injector or the fuel pressure not holding. Check the fuel pressure with a fuel pressure gage screwed on to the fuel rail at the regulator.
Jake
Old Aug 31, 2010 | 12:04 AM
jfb's Avatar
jfb
First, find out if there are any error codes stored. Next, your alternator is not working, engine running, your dash voltmeter should read 14.3 volts engine cold and this will drop to 13.3 volts when the alternator gets to its operating temperature.
Old Aug 31, 2010 | 09:49 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does sound like the fuel pump may be running off the oil pressure switch. Does the pump run for 2 seconds when ignition is switched to "run".
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Sep 4, 2010 | 04:42 PM
Stan L's Avatar
Stan L
2nd Gear
Originally Posted by jfb
...your alternator is not working...
This was the problem. The voltages I gave were with the engine off (which I presumed was the best way to test the battery). However, after exhausting all other options, I had autozone test the alternator. Sure enough, the regulator was messed up. Got a new alternator, and havent had a problem since.
Thanks so much for your help!
To new (to me) '86 with a starting problem
