no throttle response after hard turn
Old Sep 2, 2010 | 10:53 PM
blakngold4life's Avatar
blakngold4life
Default no throttle response after hard turn
I autocrossed my car for the first time at carlisle and it went pretty well. However, when exiting a corner the car would not respond to the throttle. At first I thought it was the trans acting up and not engaging into 1 (auto) but then realized the car was not even revving up to correspond with the pedal. When I tried feathering the throttle through the turn this did not happen and it ran fine, but if I tried to coast through it always would act up. Any ideas?
Old Sep 2, 2010 | 11:47 PM
rodj's Avatar
rodj
How much gas did you have in the tank?
Old Sep 3, 2010 | 07:33 AM
bjankuski's Avatar
bjankuski
Your fuel was too low, and the pump became uncovered in the corner.
Old Sep 3, 2010 | 07:48 AM
WW7's Avatar
WW7
This is a known problem.....WW
Old Sep 3, 2010 | 08:47 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
There is your answer - I have to run with at least 7 gal in the tank on road courses or I have the same problem. Below that I have starvation issues.
Old Sep 3, 2010 | 08:49 AM
blakngold4life
full tank, just filled up before the run because I thought that was the problem during the practice.
Old Sep 3, 2010 | 10:15 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
sounds like a little water in the tank or you are sloching some debris loose inside, and it is getting in the screen.
With fuel injection, that's kind of a tank issue
Old Sep 3, 2010 | 12:53 PM
aklim's Avatar
aklim
I thought there was some sort of baffle to prevent problems during cornering? Obviously if you keep doing it for extended periods of time, that might be a problem but just for one corner, I don't think so.
Old Sep 4, 2010 | 12:12 PM
blakngold4life
any suggestions on how to go about fixing this?
Old Sep 4, 2010 | 07:10 PM
aklim's Avatar
aklim
Before you fix this, check if this is the problem. Take your tank pump out. It is very simple and see what is happening. If the pickup is too high, lower it.
Old Sep 4, 2010 | 07:32 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Last time the filter was changed?
Last time the fuel pump "sock" was changed?
Good luck, intermittent issues are the darndest things to track down.
Old Sep 4, 2010 | 09:44 PM
aklim's Avatar
aklim
What has the filter got to do with the direction of the car? If it is clogged, whether it is standing still or not, what is the difference? Same with the sock.
Old Sep 4, 2010 | 10:00 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Crud in the filter or the tank moves around and creates a temp blockage.
When I replaced my pump in a Mustang it was a wonder it ever got any fuel from the amount of crud near the socks. My 92 was similar - lots of crud right where the sock went.
Shoot its just an idea, follow up on it or don't follow up on it - no skin off my nose.
Old Sep 4, 2010 | 10:50 PM
aklim's Avatar
aklim
OK. That is fair enough. Didn't think of it that way
Actually, it isn't my car that is having the problem, just wondering why the cornering has an effect.
Old Sep 5, 2010 | 02:54 AM
JimiHendrix's Avatar
JimiHendrix
Here is an idea. When you go around a turn, more revs are required to move the outer wheel in the turn. I've noticed that effect on many cars when cornering hard. The transmission is tricked briefly. Does the rpm rise when cornering hard?
Old Sep 8, 2010 | 12:24 AM
AZ86Vette's Avatar
AZ86Vette
My 86 has the same problem as the OP... We have changed the complete fuel pump assembly. No change... Odd...
Kris
Old Sep 8, 2010 | 12:32 AM
aklim's Avatar
aklim
Kris
Even with a full tank? As I said, I haven't had those problems even when I slid the car on a half tank. When I used to autocross, I ran with no more than 1/4 tank for weight savings.
To no throttle response after hard turn
Old Sep 8, 2010 | 12:58 AM
tims92's Avatar
tims92
When I autocross'd my 92, the fuel pump would suck air if the tank wasn't at least 3/4 full.
Old Sep 8, 2010 | 11:31 AM
engle1147's Avatar
engle1147
From what I've seen I think you've got a loose or shorting connector/wire in the pump circuit somewhere. When the harness/connector(s) moves the pump stops momentarily.
If it were me I'd change the in tank's fuel pump harness or at a minimum the connections on the harness inside the tank. The "crimp-on" connectors should be in stock available a most autoparts stores. Ensure the pumps sock/strainer hasn't come off and that it is making contact with the bottom of the tank. Note: The longer end of the fuel pump sock should point toward the rear of the car.
From what I've seen - these shockingly these super quick momentary fuel pump "blips" won't show up on a fuel pressure gauge....you just loose power for a fraction of a second in higher "G" loading type of a turn.
Old May 1, 2011 | 10:42 PM
blakngold4life
I've done two autocrosses and some hard mountain driving since this issue with out problem, today I autocrossed again and the issue was back. It seems to only occur on heavy right turns, I had about 3/4 tank of gas as well. Any more idea's? I haven't had an opportunity to check the stuff which has been posted yet but thought a video might bring some more opinions, issue starts around the 44 second mark.
