header questions
Old Sep 5, 2010 | 09:21 PM
BAMNCO's Avatar
BAMNCO
Default header questions
I have a 87 vette that that I put headman headers on and I'd like some advice. Do I need thremo coated spark plug wires? thanks
Old Sep 5, 2010 | 09:57 PM
87 vette 81 big girl's Avatar
Not sure what you mean by THERMO COATED PLUG WIRES.
Do you mean the aftermarket Spark Plug High Temperature Boots? They slip on over spark plug boots. Made by manufactures such as MOROSO, DCE, and others.
They will help protect the spark plug boots from the high temps radiated from long tube style exaughst header heat. They are a good investment.
Old Sep 5, 2010 | 10:03 PM
BAMNCO's Avatar
BAMNCO
could you send me a link on summit racing?
Old Sep 6, 2010 | 05:57 AM
HlhnEast's Avatar
HlhnEast
This is just one of many but this link should get you pointed in the right direction. There are a few options and you can find them in different colors. These things are not cheap. I found a set on eBay for about 1/2 price and paid almost $30 for 8 of em.
Good luck!
Stupidly I forgot to include the link. Duhhheeee, here it is.
http://www.summitracing.com/parts/THE-14260/
Old Sep 6, 2010 | 08:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Been using stock wires(no boots) for 3 years with Hedman headers, so my answer would be "no".
Having a good working set of stock looms, would be advantageous.
Old Sep 6, 2010 | 08:36 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
I am in the process of installing long tube headers on my 87 and I have noticed how close the auto transmission oil lines (going to to the radiator) are to the passenger side header pipe. I just pushed the pipes away from the pipe but they are still too close for my liking
Old Sep 6, 2010 | 09:00 AM
rodj's Avatar
rodj
Never had a problem using the stock wire retainers; they keep the wires nice and tight to the plugs.
When I went to aftermarket heads with no provision for the stock retainers I had to use the boots because length of plug wire from wire holder on centerbolt rocker cover allowed wire to hit header pipe when wire softened from heat
Old Sep 6, 2010 | 09:14 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
What is a stock loom? Is this associated with the plug wires or with the general wiring? My plug wires are all just held together by a series of plastic wire ties.
Old Sep 6, 2010 | 09:36 AM
rodj's Avatar
rodj
check your email
To header questions
