Air conditioner upgrade???
Old Sep 13, 2010 | 09:56 AM
C4vettrn's Avatar
C4vettrn
Default Air conditioner upgrade???
When switching from the old compresor oil to the new stuff do I need a new dryer?
Old Sep 13, 2010 | 10:47 AM
engle1147's Avatar
engle1147
This stuff is a good idea:
Accumulator, orifice tube, o rings (napa has a kit), 2 cans of freon, pag oil, vacuum pump and a manifold gauge set.
Old Sep 13, 2010 | 01:53 PM
C4vettrn's Avatar
C4vettrn
Is the accumulator the same as the dryer filter? I allready did the o-rings and new connections.
Old Sep 13, 2010 | 02:31 PM
engle1147's Avatar
engle1147
the accumulator has a built in (welded in) "dryer" that contains desiccant. Everytime you crack the system open it is a good idea to replace the accumulator to absorb/keep moisture out of the system. You should be able to find an accumulator between ~ $30 - $60 for your application. Install the dryer then pull a vacuum on the system if it holds move on to charging the system.
Old Sep 15, 2010 | 01:05 AM
loflyin's Avatar
loflyin
I assume this is a retrofit 134 situation. Doesn't sound like you want to invest in the entire kit from NAPA, since you have already done a good bit of work. However, it might be worth the investment in an orifice tube that NAPA sells just for this situation. It allows more flow at idle and slower engine speeds, so that you don't roast in slow traffic. I don't remember the part number, but it was in stock when I bought mine.
Old Sep 15, 2010 | 10:24 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Stop by Harbor Freight Tools and get their A/C orifice tube removal tool. It'll save you a lot of time 'cuz it's a straight ***** trying to coax that sucker out with a pair of needle-nosed pliers.
To Air conditioner upgrade???
