85 windshield wipers. Need so help here
Old Sep 22, 2010 | 01:10 AM
Pat Wells's Avatar
Pat Wells
Default 85 windshield wipers. Need so help here
I have just spent all day trying to figure out why the wipers on my 85 keep cyling in the park postion.
The switch is perfect, tore it down and inspected it, like new. This is the second motor assy on the car and it's doing the same thing.
Any ideas out there? I could sure use some ideas.
Old Sep 22, 2010 | 02:00 AM
C4boy's Avatar
C4boy
I'm by no means an expert in wiper motors, but I think the park position is controlled by the circuit board in the wiper cap.
Old Sep 22, 2010 | 07:40 AM
WW7's Avatar
WW7
circuit board may need to be replaced...WW
http://www.ecklers.com/corvette-wind...1984-1996.html
Old Sep 22, 2010 | 07:53 AM
ddahlgren's Avatar
ddahlgren
If it like a 91 there is a cam on the cover that has to be in the correct position when you put the cover on. There is a pic in the FSM. Or are saying the wipers will not stop wiping no matter where the switch is set or when you turn them off they park in random places?
Old Sep 22, 2010 | 08:13 AM
Keystring's Avatar
Keystring
If the gear 'pin' jumps out of that little groove in the blue cam or isn't installed right, it will cause your symptoms.
Old Sep 22, 2010 | 10:55 PM
Pat Wells's Avatar
Pat Wells
thanks for the idea's, Think I'll just change the unit out and see what happens. I have a feeling it may be bad windings in the low speed side of the motor.
Old Sep 23, 2010 | 12:18 AM
ddahlgren's Avatar
ddahlgren
I think you will not be happy low speed is the switch circuit board and park switch the parking in the the park switch and cam.
Old Sep 24, 2010 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Windshield%20Wipers.pdf
Old Sep 25, 2010 | 07:57 PM
Pat Wells's Avatar
Pat Wells
Thanks for the pdf file 86, that is a better one than I had in the manual. Turns out I think I have been chasing my tail on the wipers, looks like it may be a grounding problem. I posted another thread last night "wacky wipers". This thing is really weird. Threre are several problems and they seem to be related.
Old Oct 17, 2012 | 01:49 AM
FForward's Avatar
FForward
2nd Gear
Default Correct location for Cam?
I have been having problems with the delay and washer operation on my '89. I only have Hi and Lo and Mist. I have a new switch, motor and cover and still no delay or washers. On the blue cam part it has 2 arrows pointing to the cutaway part showing where the pin should be. Is this correct? The groove further into the center doesn't seem to match up right. Would a bad ground somewhere cause this? I don't have a wiring diagram and the replacement cover didn't have instructions. I have the pin on the gear right in the middle of the cutout part of the cam and its still not working. Any help would be greatly appreciated. Thanks!
Old Oct 17, 2012 | 12:27 PM
C4boy's Avatar
C4boy
It's been a couple years so I don't remember exactly, but I'm pretty sure the pin on the motor does Not go into the the blue cam. I think it just pushes the edged of the blue cam. I think you also have to have the lever in the correct position when you mount the cover. I broke my cover trying to get the pin inside the cam groove.
Old Oct 17, 2012 | 01:33 PM
ghoastrider1's Avatar
ghoastrider1
link not working
My 86 cover is not like that one on the inside...mine has a blue lever arm.
To 85 windshield wipers. Need so help here
