86 no start
Old Sep 24, 2010 | 12:20 PM
86PACER's Avatar
86PACER
I guess you didn't give them the part number I posted and instead just asked for it by name. I've found that obtaining part numbers off their site and just giving them that works the best. A lot of times you're dealing with younger guys who don't know what you're talking about. Plus their site shows in near real time weather an item is in stock at a particular store or not. I have found it to be very accurate. If it's something you have to order the shipping is usually next day and free.
http://www.autozone.com/autozone/acc...mString=search
Old Sep 24, 2010 | 12:23 PM
teamtopless's Avatar
teamtopless
i called before i read your post. I called back with the part # and he said nothing in his system at all. So the guy that did find me the light was about 28. All the 50 yr olds were clueless.
Old Sep 24, 2010 | 12:41 PM
teamtopless
Connector at the base of the dist is clean and tight. If I end up with no injector pulse where do I go from there? Icm or ecm?
Old Sep 25, 2010 | 01:53 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Care to tell us how your gonna solve this problem now??
Old Sep 25, 2010 | 08:51 AM
teamtopless
I was going to bribe you with milk and cookies Seriously though I don't care how old you are, if you are going to sell parts as a living atleast get a clue. One guy thought I was inventing a tool, Another insisted it's called a test light, while he tried to sell me a regular test light. Then I walk up to the kid, ask for a noid light and he says he could get one monday. Don't get me wrong I have all the respect in the world for you guys on here.
Old Sep 26, 2010 | 12:54 AM
jfb's Avatar
jfb
Check the two injector fuses with an ohmeter. Check for reference pulses out of the distributor. Swap the ECM with a known good one.
Old Sep 26, 2010 | 04:26 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by AGENT 86
The ECM looks for a reference signal from ignition module, before it will fire the injectors. Be sure the 4 pin connector at base of dizzy is clean and tight.
Where exactly is the 3 pin connector at the base of the dizzy? Do you mean the base of the distributor? Is the connector in the front or back? Might you have a photo or diagram?
Old Sep 26, 2010 | 04:27 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Where are the two injector fuses located? How do you check for distributor reference pulses?
Old Sep 26, 2010 | 07:54 PM
teamtopless
The connector he is talking about is on the driverside of the dristributor towards the firewall. The injector fuses or on the very right hand side of the dash. Open the passenger door and look for the cover on the side of the dash. Im used to building jeeps. This is my first corvette rodeo so I know very little.
Old Sep 28, 2010 | 12:12 PM
teamtopless
Ok, got my noid light. No injector pulse. I pulled the ecm down, connectors are tight and clean. I tapped on it lightly with no change. Bad ecm?
Old Sep 28, 2010 | 07:54 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do you get a code 12 when looking for stored codes ?
Old Sep 28, 2010 | 10:41 PM
teamtopless
No codes stored at all.
Old Sep 28, 2010 | 11:16 PM
  #33
AGENT 86's Avatar
AGENT 86
Code 12 should always be there. Are you using that scanner, or jumping "A" and "B" on the ALDL connector and counting the flashes of the SES light ?
Old Sep 28, 2010 | 11:18 PM
  #34
teamtopless
Just using my snap on scanner. Do you recommend the old school method?
Old Sep 29, 2010 | 08:07 AM
  #35
AGENT 86's Avatar
AGENT 86
Yes, your scanner has some questionable readings.
Old Sep 29, 2010 | 08:08 AM
  #36
AGENT 86's Avatar
AGENT 86
Also, do you know if the crank enable relay has ever been bypassed ?
Old Sep 29, 2010 | 11:50 AM
  #37
teamtopless
Well I got it running today. Threw a new ecm at it and she fired right up. Runs very well with excellent oil pressure. Thank you very much for all of the help guys.
