Starter Problem
Old Sep 24, 2010 | 05:51 PM
grantar2's Avatar
grantar2
Default Starter Problem
Car is a 1990 L98 with the ZF 6sp. I have less than one year old starter that has given me problems when that car has been run hard or the ambient temp is very high. It occurred today for only the second time in a non-race condition. Usually this happens between runs on gird if I shut down. Turn the key nothing happens. If I push start the car it will fire and the starter usually works after that.
Any ideas? Is it the starter itself or do others have this happen. Today is a 100 degree day.
Old Sep 24, 2010 | 07:11 PM
jfb's Avatar
jfb
If you can hear the starter solenoid click but the starter motor doesn't crank, then you likely have bad switch contacts in the starter. There is a large copper contact that is forced against another contact at the end of the starter solenoid stroke which switches 12v to the starter motor. This contact gets blackened and pitted and eventually doesn't make a good enough connection to supply the 100+ amps the starter motor requires. If you do hear the solenoid click, you can keep hitting crank and the starter may eventually crank when the solenoid breaks through the pitting on the contacts. You can replace the contacts in the starter. If you use the search function, some posters have given the part numbers for the replacement parts.
Old Sep 25, 2010 | 12:14 AM
grantar2's Avatar
grantar2
Thanks, I will look the part numbers up, however when it wont start it dead silent, no solinoid no nothing. Plenty of battery, all other system work, just no starter no noise, no cranking. My mechanic will warranty the part, but it will cost me the labor to have it changed out. Was wondering if this might be common as it most often happens after I have just flogged the car on track.
Old Sep 25, 2010 | 12:50 AM
rodj's Avatar
rodj
Heat soak is a common starter problem but the Denso units used in the late C4's don't seem to suffer as much as other types; partly on account of being a mini starter and mounted further away from the headers
Old Sep 26, 2010 | 12:50 AM
jfb's Avatar
jfb
Heat soaked or not, the starter solenoid should click. You don't have a VATS problem because you can push start the car. I would check the clutch safety switch, unplug it and bypass it with a large wire. Measure the voltage on the jumper in crank position, it should have 12v on it. You can jump 12v to the jumper and the starter should crank. If no 12v, you may have a defective start enable relay, measure the voltage on each side of the relay contacts. If no 12v on either, back up to the ignition sw and see if you have 12v out of the starter wire from the ign sw.
Old Sep 26, 2010 | 10:20 AM
SJW's Avatar
SJW
The fact that this is a heat-related fault points to high resistance in the low-voltage start circuit. Check and clean all of the contacts that you can get access to (ring terminals at the starter, etc), and also freshen up the connections at the battery and the ground straps to the chassis and engine block. If the problem persists, try a new solenoid. Or try a new solenoid first. (I'd do both, much as I hate having a car that won't crank when I want it to).
Live well,
SJW
Old Sep 27, 2010 | 05:30 PM
TheKid!!'s Avatar
TheKid!!
Default I had similar starter issues...
I bought a new starter put it in it worked for a while and started to fail.
I then bought a beefier starter (more expensive), new solenoid, cleaned all contacts cable with electrowash and a small wire brush and changed the alternator. the starter has worked ever since. I think the real difference was I did all the work myself the second time and made sure that starter was in there good and tight. It didn't come out or go in easy. Hope this helps.
To Starter Problem
