A clogged radiator wouldn't explain how the temp is getting to 230 within a minute of a cold start. That is why the focus would be on a possible headgasket failure or possible crack.
But a head gasket also would not make the bottom of the radiator remain totally cold while the top hose is totally hot.
If you want to know about the head gasket then do a quick block test with dye and find out in seconds. You can RENT both the dye and the tester at Autozone with refundable deposit or you can also just buy it. It's like $25 for the tester and about $8 for the liquid dye. Fast and easy.
I agree it sounds like a possible clogged radiator. But it looks like to me there are 2 problems. One is a possible clogged radiator. The other is the car is getting to 230 within a minute of a cold start. That shouldn't be happening. It doesn't matter if the radiator is clogged or not with regards to reaching 230 within a minute.
I agree. But his leak down rate seem to check out fine. #6 compression is low though. Almost a 50 psi difference from 1 2 and 8.
That's more than I would like. He didn't seem to do a "wet" test. I saw 197-200 psi dry across all 8 on mine. I would add a block test with dye.
I've read some people having a blown headgasket with good compression and a good leak down. But it still sounds like something major. Or possibly a bad sensor. But I figure if the temp gets to 230 that fast, you should be able to put your hand on the engine to confirm it's hot to rule out a bad sensor.
If the top hose is hot and the bottom hose is cold at those high temps it's a clear indication of a coolant circulation problem and that's where I would be focusing my attention not a head gasket.
- and to me it sounds like a clogged radiator. if the OP indicated the inside of the radiator looks horrible, i'd just bite the bullet and install a new one - sound like his car needs it anyway...
Okay, this is what I plan to do. Once I get my new plugs installed, then I will put the front of the car on ramps to eliminate any possible air bubbles in the system. Then I will remove the radiator cap and crank the car. If the coolant on the cap side gets sucked down, then the pump is working. And if the radiator is clogged, then coolant will trickle or not from the other side. I might also remove the thermostat to eliminate the possibility. I ran the compression check in order to make sure that I didn't warp or crack a head and to make sure the head gaskets are okay. Now, I feel that either the pump or the radiator is the issue. A new thermostat will go in because those are cheap. I think that this simple test will tell me if I have a bad radiator or pump without additional tools or a big mess on the garage floor.
As stated, a clogged rad and stuck stat, won't come into play for 5-10 minutes of idling, from a cold start.
How can either of those be the problem if the temp reaches 230* in a single minute ???????
At this point, I'm hoping that the block is a little low on coolant which would expose both temp sending units to air. The air temp would definitely rise that quickly. When I get the car up on ramps and top to cooling system off, hopefully this will change.
The radiator doesn't come into play until the thermostat opens. This is at least a few minutes after start. The one minute and 230 degree thing means something is amiss with the motor. To the op, did you do an actual leakdown test or did you just hold the pressure from the compression test? Race motors leak more than 1%. The pressure in cylinder #6 is going somewhere.
How would the radiator cause the cold engine to get to 230 in a minute?
I'm betting the OP needs a new stop watch or he has way way less coolant in the block than he thinks.
If no sign of H20 in the oil and head gaskets check out then I'd flush the block and hoses - pull/replace the T-stat to see what kind of "gunk" pops out of the cooling system. Might be time for a new pump and radiator as well.
good luck -
The OP (myself) likely does need a new stopwatch. I could be way off on the minute to 230 deg. I didn't use a watch, just a guess. Time sure does seem to fly when the temp numbers are rolling up. It could have been 2-3 minutes. I'll have to get a stop watch to make this more scientific.
I also think that the coolant is likely low in the block which will throw the temp readings off. The heater core probably weeps a little. Either the water pump is dead or the radiator is clogged. I'm working late every night for the rest of the week so it may be a few days before I can continue to diagnose.
I just let the compression guage sit for a minute after each test to verify that there was no pressure loss.
You must know that a compression gauge has a pin that releases the pressure. Without releasing the pressure, the pressure only can go up between cranks and does not decrease, hence your 1% or less leakdown. Get a real leakdown gauge and see what is going on. You might find that you have a gasket leak beteen 6&8.
Yes, that does make sense. I did wonder how the pressure held with the valves possibly being open. I learn something new each day. I really hope there is no gasket issue.
383vett,
Could you elaborate a little on what's involved in the leak down test? I am imagining a device with a guage that allows one to pump compressed air into individual cylinders at TDC or when both valves are closed.
Hi Anthony. A leakdown gauge has two gauges, one to measure the pressure of the air going into the cylinder and the other to measure the pressure of the air leaking out. You need an air compressor for to use this gauge. It is screwed into the spark plug hole with the piston at top dead center and the valves closed so theoretically, the cylinder is pretty well sealed up. Listening to where the air hisses out of the cylinder will give you an indication of where the air is leaking. Someone will soon post a picture of the gizmo. Hope this helps.
I can't see anything, except for the exhaust and exhaust gases, getting that hot that fast.
Get the dye and test for exhaust gas in your coolant.
