406-409 ci thread
Old Oct 5, 2010 | 03:28 PM
LD85's Avatar
LD85
Dyno called today my numbers according to the phone call are below, I will post the dyno sheet when I pick up the car on Friday.
425-RWHP & 458-RWTQ on Dynojet
HSR Plenum by me
AFR 210 heads (last Gen) 1206 gasket
11:1 CR
238/242 Hyd-Roller custom billet cam spec'd by me by Bullet Cams
Comp Cams Roller Rockers & Retro Lifters
Eagle Forged 4340 Crank & Eagle Forged H-beam rods
Wisceo Forged Pistons
Hooker 2149
58 MM TB with 165 ECM and stock MAF sensor
MSD 6AL w/8366 Distributor
Kirban AFPR
Walbro 255
FIC Bosch 42# injectors
TKO 600
3:45 (ZF) rear gear
Kevko Oil Pan
Melling 10555 Oil Pump
Flow Kooler water pump
Dewitts radiator
That's about it
Old Oct 5, 2010 | 11:12 PM
88BlackZ-51's Avatar
88BlackZ-51
HSR Plenum by me
11:1 CR
Hooker 2149
Kirban AFPR
Walbro 255
TKO 600
3:45 (ZF) rear gear
Kevko Oil Pan
Dewitts radiator
That's about it
Good Job! That's some good torque. Curious to see how I compare if I ever get this thing started.
Old Oct 6, 2010 | 12:59 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Soild!
Not so surprised you busted up your 4+3 now...
Old Oct 6, 2010 | 08:11 AM
LD85's Avatar
LD85
Thanks guys, the car is very streetable which I like, and after trying so many different combinations, I learned a lot for sure.
Dyno numbers seem to vary from dyno to dyno but I am happy with how it turned out. I did not want a cranky street machine, or max HP numbers,,,,,I have gone as far as I will go with this car...
I've got my sights set now on buying and rebuilding a 1965, 66 or 67 Convertible GTO next
Old Oct 6, 2010 | 09:32 AM
mseven's Avatar
mseven
congrats, I know you've been working with it for awhile now and it's paying off...
Old Oct 6, 2010 | 11:08 AM
88BlackZ-51
do u have a video of how she idles?
Old Oct 6, 2010 | 11:42 PM
Crepitus's Avatar
Crepitus
Old Oct 6, 2010 | 11:55 PM
1985 Corvette's Avatar
1985 Corvette
I second this. LD85, I've seen your threads over on digital corvettes. You've got some excellent fabrication skills. Since I'm assuming people are dumping a fair amount of cash into these 400+ cid builds, are the majority going the extra mile with balancing components?
Probably a dumb question but I've heard lots of "not necessary waste of money on street engine" vs "makes for a smoother revving engine".
Old Oct 7, 2010 | 12:35 AM
JAKE's Avatar
JAKE
Next time you come across a thread where someone is advocating AGAINST having an engine balanced PLEASE post the link here.
I'D REALLY APPRECIATE IT.
I want to post my VEHEMENT DISAGREEMENT with that foolishness in an effort to try to keep it from spreading like a Cancer.
Jake
Old Oct 7, 2010 | 08:23 AM
Pete K's Avatar
Pete K
In the link below, I documented my 406 budget build. I did not intend to build it cheap. I tried to put together something good, based on parts that I already owned, and what I felt was nescessary for my needs. As you can see from the totals, price to build was reasonable.
http://www.corvette-guru.com/modules...mode=0&start=0
In regards to balancing, some choose to re-balance a factory motors rotating assembly during an overhaul. Because the factory has a wide range of tolerance, a good crank balance can make a world of difference for a few bucks.
In the case of aftermarket stuff, they all require balancing, as the crank manufacturer has no control, or idea of what part will be hung on their crankshaft. Therefore, balance is required ever time a rotator is assembled. The exception would be if someone cobbles all the parts together, balances it, then sells it as a complete, balanced rotating assembly. However, I have found that most of these could stand to have the balance touched up because of so-so workmanship.
My opininion is all rotating assemblys need to have the balance checked, then tweaked. Cheap insurance that adds durability to the build.
Old Oct 7, 2010 | 08:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
Youll hear lots of stupid unfounded hack em up bits of advice on the internet. Some of the fixes, even seen here are downright scary. Most times those posting that have no experience they just read that from someone else who read it....
As said above balancing adds durability NOTHING is more irritating than having one out of balance.
Years ago I ordered a P.A.W. shortblock and,even with thier balance job the motor shook like there was no tomorrow. SHould have known it was a cheapie build. I got what I paid for I guess. AFter getting 3 bad cranks I should have shoved their motor over the counter and gotten my coin back.
Bearings were about wiped after 1500 miles. THey are closing down this month serves them right.
Old Oct 7, 2010 | 11:32 AM
Orr89rocz's Avatar
Orr89rocz
HSR Plenum by me
11:1 CR
Hooker 2149
Kirban AFPR
Walbro 255
TKO 600
3:45 (ZF) rear gear
Kevko Oil Pan
Dewitts radiator
That's about it
What rpms for peak power and torque? Do you have a graph?
Old Oct 7, 2010 | 06:30 PM
  #33
LD85's Avatar
LD85
No dyno graph until I pick it up, Saturday I hope,
As far as balancing, accurate balancing is always a must...and I have had mine balanced as a stock external 400 front and rear,,,,,, neutral front and external rear, and finally and best,,,, all neutral.
Once lesson I learned, is that in the long run, it costs less to buy a balanced rotating assembly complete, (rods, crank and pistons) rather than trying to find deals on separate components and then having them balanced.
Old Oct 7, 2010 | 11:02 PM
  #34
1985 Corvette
Lots of good info from everyone so far! Ron, what kind of questions were you putting out there while shopping around for the right shop to do the engine work?
Old Oct 7, 2010 | 11:23 PM
  #35
cv67's Avatar
cv67
St. Jude Donor '05
The basics.....asked some local higher end shops who they recommended. Guy that machined my current one specializes in balancing turns out most shops send theirs to him so that helped.
I never asked price just found a way to pay for it. Even with a pretty roudy cam it doesnt so much as twitch...at all.
Old Oct 8, 2010 | 01:01 AM
  #36
USAsOnlyWay
So that raises the question, if you buy a balanced rotating assembly (ala Eagle, Scat or the like) does it need to be verified?
Old Oct 8, 2010 | 02:16 AM
  #37
LD85's Avatar
LD85
Probably, but checking it cost less than balancing,,, I would have to look up my cost for balancing,, but I want to say it was $200 , just going from memory. Sine I have not bought a balanced rotating assembly, I would say that it probably depends on who you buy it from with regard to accuracy etc.
To 406-409 ci thread
Old Oct 8, 2010 | 07:28 AM
  #38
Pete K's Avatar
Pete K
Prolly different opinions for that question.
In my opinion, never trust the stuff that comes in the mail. Check everything.
Old Oct 8, 2010 | 11:25 AM
  #39
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
with Pete. You'll find is not up to specs, unbalanced or dirty.
This is how I learned about Tungsten
Old Oct 8, 2010 | 11:43 AM
  #40
USAsOnlyWay
But I think you guys, especially Pete, have a large sample size to draw off of when you make those conclusions than I do. Always good to get a unanimous decision.
Have fun picking up the car Larry, you'll have to let us know how the driveability is with the improved tune!
