Evap box and pullys, what do you think?
Old Oct 4, 2010 | 12:53 AM
Doughboy2k3's Avatar
Doughboy2k3
Default Evap box and pullys, what do you think?
What do you guys think of my evap box delete? Special thanks to Aardwolf for the help.
Also my pully delete, I moved the alt to the passenger side with hopes of a blower in the future.
Old Oct 4, 2010 | 09:44 AM
Aardwolf's Avatar
Aardwolf
No prob! You will love how easy it is to change the plugs and work on that side of the engine.
Old Oct 4, 2010 | 03:34 PM
Pwnage1337's Avatar
Pwnage1337
Looks extremely familiar..
Any more pics of your project ?
Old Oct 4, 2010 | 05:33 PM
Doughboy2k3
I dont have alot of pulley pics. But this is what I have.
Old Oct 4, 2010 | 08:17 PM
joeld's Avatar
joeld
Very nice fabrication work!
Do you still have the AC Compressor support brackets, (3)? If so, and if you want to sell them let me know. Thanks
Joel
Old Oct 4, 2010 | 08:33 PM
Aardwolf's Avatar
Aardwolf
I've got that same oil pan gasket, it's really a nice product.
Old Oct 5, 2010 | 12:32 AM
Pwnage1337's Avatar
Pwnage1337
Wow looks like a nice build you have going there.
Did you have your block bead blasted? Looks extremely clean.
Old Oct 5, 2010 | 12:42 AM
Doughboy2k3
Thanks, I ended up using a new Dart SHP block.
Old Oct 5, 2010 | 11:32 AM
8valve's Avatar
8valve
I am looking at removing the evaporator box also, but still want my heater. Did you set the air door to the heat position and lock it. By any chance, did you make a template of the new fab'ed box that you woudl be willing to share ?
8Valve
Old Oct 5, 2010 | 03:20 PM
Doughboy2k3
8Valve
I left the door how it was. I just fabricated the intial box out of cardboard. I started with the upper and lower section, I then made the top cover. It will only cost about 10 dollars to make, it is just time consuming. Let me know if you need measurements or anything else that can help.
Old Oct 5, 2010 | 04:01 PM
8valve's Avatar
8valve
Great Idea to make the original out of cardboard. One question.
On top of the Evaporator Box are two electrical plugs that plug into a heat sink with electrical components that hang down in the Evaporator box. Can that sensor be unplugged, and wires tied back and still have full use of heater controls. I dont care a bit about AC, but up here heat is important.
8Valve
Old Oct 5, 2010 | 05:32 PM
Doughboy2k3
8Valve
I think that the heatsink gauges your temp and will adjust the fan speed accordingly, I could be wrong. I just cut a slot for the heatsink and popped it in.
Old Oct 5, 2010 | 05:38 PM
Doughboy2k3
Aardwolf,
Its a nice unit. Every part I used came from the recommendations of the guys on the forum. So far it is going together nicely. I have been taking vacation time to work on it.
Old Oct 5, 2010 | 06:10 PM
Aardwolf's Avatar
Aardwolf
After my thread about this I changed mine. I had the electronic control like that too. I removed the C68 so I could sell it and now use a manual blower fan switch for heat/defrost.
Old Oct 5, 2010 | 06:50 PM
8valve's Avatar
8valve
Ok, sounds great. The manual fan button are fine with me.
8Valve
Old Oct 5, 2010 | 07:18 PM
Aardwolf's Avatar
Aardwolf
8Valve
NP! I used a 20 amp inline fuse with it. I had to make a bracket and cover box on the inside, similar to the one above. There is a pic of the switch in my thread about it here:
http://forums.corvetteforum.com/c4-t...race-dash.html
To Evap box and pullys, what do you think?
