transmiision cooling
Old Oct 11, 2010 | 04:18 PM
mrbillybob's Avatar
mrbillybob
Default transmiision cooling
Has anyone bought a DeraleTransmission Pan Cooler#14104. They advertise 20-50 degree drop in temperature. Would I be better off buying the B&M 71074 cooler, and plumb off the radiator into their 1/2 # female fittings.
Old Oct 11, 2010 | 04:30 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I had a B&M 70268 plate type mounted in front of the AC condensor on my 95A4 and achieved the temp drop you are looking for.
Old Oct 11, 2010 | 05:02 PM
mrbillybob's Avatar
mrbillybob
Default Mounting B&M Cooler.
Did you mount it on the upper fan shroud?
Old Oct 12, 2010 | 02:30 AM
Mr. Peabody
Nope mounted it directly to the lower left front of the condensor down at the bottom.
Old Oct 12, 2010 | 10:15 AM
twin540's Avatar
twin540
I have both. Just installed the derale pan and thermal rapped my exhaust around the tranny. Noticed a consistent 170 degree engine temp. About 30 degrees cooler
Old Oct 12, 2010 | 10:21 AM
twin540's Avatar
twin540
I'm sure it cool evenmore but I have a 180 tsat. Cool even faster then before once I get on the highway.
Old Oct 12, 2010 | 06:37 PM
pvvette's Avatar
pvvette
5th Gear
I installed the Derale Transmission pan cooler on my stock 1996. Driving on the highway, I noticed an overall drop of about 10 degrees on average. The trans temp use to rise to about 190 during highway driving and then level off. After the installation of the pan, I noticed the trans temp with normal cruising on the highway to be about 180. It also took more time for the trans temp to rise. I later installed a flex-a-lite transmission cooler (#4118) in conjunction with the pan and have observed trans temps around 160 with steady cruising. With that said, the Derale pan does drop trans temps, just not that much. However every little bit helps. The pan also allows for an extra quart of fluid and does have a convenient drain plug to make it a snap to drain the pan.
Old Oct 12, 2010 | 07:22 PM
Calderone's Avatar
Calderone
Hi,check this thread and this thread,those are my experiences
Derale pan is one of the best mods i've ever done !
Old Oct 14, 2010 | 12:07 PM
mrbillybob's Avatar
mrbillybob
Default Thanks
Thanks for all the input.REALLY HELPFUL
To transmiision cooling
