Used opti install
Old Oct 16, 2010 | 11:38 AM
C4fan's Avatar
C4fan
St. Jude '10
Default Used opti install
During my 383 build I will be installing my used opti. The shaft as shown in the pic has a little play. Is this normal the opti has about 10K miles? It's not much but I can easily feel it. Also what tool/socket is used to take it apart to silicone it? The tiny screws look like some sort of torx head.
Old Oct 17, 2010 | 10:58 AM
C4fan's Avatar
C4fan
St. Jude '10
Does anyone have a new one that they can grab real quick and try to wiggle it?
Old Oct 17, 2010 | 12:09 PM
mtwoolford's Avatar
mtwoolford
those little bugger screws are 4mm reverse torx head; sears sells the socket, catalogue only, don't have the number with me, $12 when I bought mine. However....use some small vise gripes to grab a bolt with a 4 mm torx head, place it on the the reverse head on the opti, and presto, use it to unscrew those odball opti screws.
Old Oct 17, 2010 | 12:18 PM
C4fan's Avatar
C4fan
St. Jude '10
OK that's too easy, thanks for the tip. I'll give that a try.
Old Oct 17, 2010 | 12:22 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The screws on the top of the TB that hold the plate and a pair of channel locks will work or don't be cheap and go to the auto parts store (or Sears) and get a set of torx sockets.
Old Oct 17, 2010 | 01:16 PM
C4fan's Avatar
C4fan
St. Jude '10
Everytime we go to the mall here I park by Sears and my wife has to put up with me cruising through the tool section. I'm always adding to the shop. Tips like the one above are good to know as the mall is a 30 mile drive one way and sometimes you just have to get creative rather than loosing the time. The reverse torx sockets will be on my list to look for. Again, thank you for the tip.
Old Oct 17, 2010 | 01:36 PM
STL94LT1's Avatar
STL94LT1
I just checked a new opti, it also has a slight bit of play. Once it is inserted into the end of the camshaft it should be smooth sailing.
Old Oct 17, 2010 | 07:27 PM
C4fan's Avatar
C4fan
St. Jude '10
Good to hear. That peace of mind will go a long way.
Thank you very much.
To Used opti install
