Has anyone removed all of the components that make the EGR system? If so what all needs to be blocked off as far as vacuum lines and exhuast lines. I have block off plates for where the valve itself goes and for the thick pipe that comes off the headers do i need anything else????? What about electrical or idling problems after removal?
All replies will be greatly appreciated!
thanx
If you have an L-98, removing the EGR will NOT throw off any codes- can't speak for LT-1's, tho... I've had the EGR system off my 86 for five years now, runs perfect, no more heat running into the intake- and no idiotic clamps and hoses to fool with anymore- reason alone to remove the system!
I wouldn't do that. Rumor has it that when the democrat proposed bill to encourage scrapping 15yr+ "fuel inefficient" cars with "financial incentives" bites the dust, that the compromise may be a federal crackdown on emissions. Just a hearsay rumor though :rolleyes:
What does the computer use for feedback to determine that the EGR in not operating and show a code?
If the soleniod is still connected but the exhaust pipe from the manifold is removed (blocked off) how does it know no flow is happening?
What is the purpose of the sensor in the pipe from the manifold to the exhaust pipe?
I believe the 90-91 cars are more prone to throw a code 32 when taking off the EGR due to the speed density set up
I removed the EGR on my 90 L-98 when I installed my miniram. I believe our cars have the same computer. A code 32 will turn on during cruise conditions. A PROM programming change is required to disable the code. Do not know enough about programming to tell you what to change. The intake will run cooler, which = HP. Bypassing the coolant into the throttle body and changing the fan temp will also help the engine to run cooler. You should be able to run more timing with these mods. I had no problem passing emissions.
However, your car will not pass the visual inspection. I think that it is ridiculous to be required to have emissions equipment that is not required to meet the standards.
Answer to your questions all stem from that sensor in the pipe from the exhaust to intake manifolds. The sensor records the temp of the air inside the pipe. If the ecm is call for EGR flow, then the sensor should see an increase in the temp of the air flowing in the pipe. If no increase in temp, then code 32. Mine was throwing this code, but only intermittent. After I removed the EGR during teardown, I discovered by I was getting the code. EGR pintle would not move, was stuck closed by years of carbon deposits. As I live in DFW metro area and we are under even greater scrutiny for emissions this year, all devices will be put back on the car and will be functional. After some research, with the exception of racing (in organized, sanctioned events) I don't feel like the emissions gear hurts the performance enough to consider removal. Now back in the 70's...... :rolleyes:
