86 Heater Control gone WACO
Old Oct 27, 2010 | 10:41 AM
tdf's Avatar
tdf
St. Jude Donor '11
Default 86 Heater Control gone WACO
Fall is in full force now so I have need for heat. I have the "automatic" version of the controls. First time I turned set the heat controls on I noticed that the engine warmed as usual, but the air continued blowing cold. Then suddenly the heat came on full force and I could not shut it off. Doesn't matter what control buttons you set she pumps heat once it starts to work.
BTW: My AC hasn't worked for a couple years but this heat control issue just started.
Any ideas?
Tom
Old Oct 28, 2010 | 09:12 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like the blend door is stuck on full heat. Could be a bad motor or broken clip between motor and rod or rod and door. The 86 has a water control valve that is operated by vacuum, so that would have to be stuck open, also.
If you remove the blower control module from housing and look inside, you should see the door moving from one side to the other, when the temp is switched from cold to hot, while in auto mode.
Here is some info from my 86 FSM
http://members.shaw.ca/dankai/HVAV'S.pdf
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Here are some pics from my heater core project, some show the motor, door and rod.
http://members.shaw.ca/dankai/Heater%20Core%201/
Old Oct 28, 2010 | 09:39 AM
Keystring's Avatar
Keystring
There is another possibility as well.
My CC would do the same thing and 'flake out' with the display going nuts.
I removed it and took the controller out of it's case.
There is a board that plugs in the back of the controller head.
Pull it out and clean the contacts real well. They get corroded over time.
Reassemble and reinstall.
I did this with mine and everything works fine now.
Old Oct 28, 2010 | 10:46 AM
tdf's Avatar
tdf
St. Jude Donor '11
Default Thanks
Thanks for the replies! Now I have an idea of where to start probing. Appreciated!
Old Oct 30, 2010 | 12:03 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default Fixed (was electrical problem)
I decided to go for the electrical first, so I removed the control unit from the dash to check it out. No apparent corrosion at all. However, when all put back together the HVAC controls are functional again. Must have been weak/dirty contacts on either the main connector or the PCB.
Old Oct 30, 2010 | 02:52 PM
Keystring's Avatar
Keystring
Did you remove the control head from it's case?
The contacts between the front head and board are what I found
to be dirty and corroded somewhat.
Sometimes you really don't see the oxidation. It may 'look' clean, but there could be
a very thin film on the contacts. It's better to clean them with a little emery so you don't
have to take it apart later on.
I'm glad it's working for you.
Old Oct 31, 2010 | 10:19 AM
tdf's Avatar
tdf
St. Jude Donor '11
Default Yes - Removed from Box
Keystring.....Yes to your question. That's why I mentioned the PCB connector. I pulled the PCB out of the box and cleaned those contacts as well. Used spray electical cleaner and a soft cloth. Hopefully that takes care of the issue for a while anyway.
Old Nov 1, 2010 | 09:38 AM
Keystring's Avatar
Keystring
Excellent.
I haven't had anymore problems with mine either.
Makes you wonder how many have sent theirs out to be repaired when it was probably just dirty contacts.
Old Jan 20, 2011 | 01:04 AM
tdf's Avatar
tdf
St. Jude Donor '11
The Grimlins are back! I was afraid of that. This time I do have the ability to cycle the blower off and on, so cleaning the ICBs did improve the elctrical side of things. With more driving time I now know that a door is sticking somewhere inside the heater internals. If the heat won't come on (this is gonna sound weird, I know) I can make a sharp brisk right turn and hear a door go "plop" and I instantly have heat. So I need to get inside and see whats sticking and why....Grrrr
Old Jan 20, 2011 | 09:03 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Sometimes the rubber seal is affected by smog and age and softens. Then it makes a really GOOD seal. Try putting armor-all on the seal to slicken it up.
Old Jan 20, 2011 | 10:33 AM
engle1147's Avatar
engle1147
From your description it sounds like your good electrically now it seems you just have a mechanical problem (loose actuator, loose rod, broken plastic clip for the rod, blend door hinge issue) with the blend door function. Pull the passenger side knee bolster/hush panel and have someone work the AC/heater controls to adjust the blend door open/closed so you can see what is what.
Old Feb 27, 2011 | 08:14 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default Blend Door Rod Clip
Finally found some time to work on this issue!
Agent 86 and engle1147....you were correct! The clip that holds the rod for the blend door to the actuator motor arm is missing! I found what looks like it might be 1/2 of the plastic clip on the floor. Is that clip a white colored clip? I was able to see that the acuator motor is working (moving the lever when changing the heat setting on the control panel). Just got to get a replacement for that clip or make a mechanical connection between the arm and the rod some other way.
I wonder if GM has that clip?
Thanks for the Tips Guys
Old Mar 5, 2011 | 11:55 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default My Own Solution - Actuator Re-Attachment
After finding that the plastic clip was a discontinued part I decided to come up with my own solution.
The blend door rod is threaded 10-24 (figured out by trying nuts on it until the threads matched). Starting with a 1/2 inch by 1/2 inch aluminum bar, I cut a short piece and drilled and tapped one end 10-24 to thread. That side will attach to the rod threaded to it. On a perpendicular side I tapped a M6 x 1.00 thread hole to take a bolt for connection to the motor lever arm. With the bolt bottomed out it should be locked in for good. I don't think I will need worry about the connection anymore. :-)
Old Mar 6, 2011 | 12:01 AM
tdf's Avatar
tdf
St. Jude Donor '11
Default Pictures
Here are pics of the design I came up with.
Old Mar 7, 2011 | 10:59 AM
engle1147's Avatar
engle1147
Excellent fab work!
To 86 Heater Control gone WACO
