Best way (any way) to reduce hydraulic rocker/lifter noise?
Old 11-01-2010, 02:22 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
Default Best way (any way) to reduce hydraulic rocker/lifter noise?
Love the way the car runs -- especially when cold. As it get near op temp (180ish), there's more noise in the top of the motor.
I suspect the injectors are making at least part of the noise (one sounds even louder than the others). Obviously, that would require replacement and is not at issue.
My builder listened to it and said it's the nature of roller rockers. He said if I returned to factory style, it would be more quiet -- though he said my heavier springs would eat 'em up. That's not really what I'm looking for though.
My clearances are .002" for rod bearings. Pistons are about the same. Lifters are the LS style that GM designates for all hydraulic lifter replacement these days. One of my thoughts is if oil weight can make a difference?
The obvious route would be to try heavier oil since my rod/bearing/piston clearances are slightly higher than stock. OTOH, my lifters are put in motors where 5w-30 is expected. Maybe their clearance is MUCH tighter (and would operate better with thinner oil)?
So far, I've only run 10w-40 and I'm at 3k miles on the 383. Any votes on whether to go heavier or lighter (oil) on my impending oil change? Any other suggestions?
FWIW: I'm running Comp Pro Magnum Full Rollers with just under 1/2 turn preload. They have poly locks. (Rocker noise isn't "bad",,,just that it's louder than stock level IMO. I was just hoping for less noise with lower resistance compared to stock.)
Thoughts, experiences, suggestions?
GREGGPENN is offline
Old 11-01-2010, 03:14 PM
GREGGPENN
GREGGPENN's Avatar
I forgot to include I'm running good oil pressure (30 at idle) and up to 80psi at 5k rpms. It's an updated Melling 3/4" 10542 oil pump IIRC. The cam has 544" lift with 216 duration. (VERY similar to the SR cam.) Springs are 155# dual coil.
Also, I'm only talking about noise at idle.
Old 11-01-2010, 03:52 PM
SaberD
SaberD's Avatar
i switched to amsoil 5w30 from mobil1 5w30. i noticed a slight decrease in valvetrain noise after the change.
SaberD is offline
Old 11-01-2010, 03:53 PM
WW7
WW7's Avatar
Roller rockers have always been louder then stock rockers. When my 383 was built it was quieter then most I have heard with rollers, but now that I have some miles on the motor its noise level has increased to where I would expect rollers to be. I wouldn't go changing oil weight just to quiet the rockers. On a new motor once the engine is broken in and the parts are worn into each other its not a bad idea to adjust the rockers again. I will be doing mine soon at 5000 miles and adjusting them to 3/4 turn past zero lash.When Pete K built my engine he adjusted the rockers 1 full turn, not 1/2 turn at zero lash. I would listen to your builder on matters concerning your motor, he should know best..WW
WW7 is offline
Old 11-01-2010, 05:47 PM
C409
C409's Avatar
Headers are also noise culprits ... they tick a lot ...
C409 is offline
Old 11-01-2010, 05:56 PM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
I went nuts trying to figure out why I had noise in the valve train, setting & re-setting the lash etc. Then I found out about the RR's being noisy & just learned to live with it. It takes some getting used to but after a while you will accept it.
Midnight 85 is offline
Old 11-01-2010, 06:47 PM
383vett
383vett's Avatar
Received 1,547 Likes on 1,046 Posts
I don't think you would want more than 80 psi oil pressure. I can't hear my rockers because of open headers.
383vett is offline
Old 11-01-2010, 08:42 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
It wont go away, rockers make a little noise and the quicker opening and closing ramps will too nothing you can do just the jature of the beast. Those are man sounds anyway deal with it.
Boy youd hate a solid roller
cv67 is offline
Old 11-01-2010, 08:48 PM
pr0zac
pr0zac's Avatar
i wish my car was quiet enough to hear my rockers.
pr0zac is offline
Old 11-01-2010, 09:13 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
turn up the radio
PLRX is offline
Old 11-01-2010, 09:30 PM
Midnight 85
Boy youd hate a solid roller with .020 lash driving around.
Or the old Corvette solid lifter fuelie cam known as the 30-30 because of it's lash setting.
Old 11-01-2010, 09:35 PM
slickfx3
slickfx3's Avatar
some guys are so good they can hear my forged pistons, the built engine is gonna snort and hiss....
slickfx3 is offline
Old 11-01-2010, 09:50 PM
cv67
cv67's Avatar
St. Jude Donor '05
Thats called music
cv67 is offline
Old 11-02-2010, 12:57 AM
lt4obsesses
lt4obsesses's Avatar
So long as it sounds more or less like a sewing machine, that's what they sound like. Oil weight and viscosity will not have any significant effect, I've tried it.
lt4obsesses is offline
Old 11-02-2010, 02:38 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
That include the roller tip style rockers as well?
JrRifleCoach is offline
Old 11-02-2010, 08:46 AM
Midnight 85
Sure does.
Old 11-02-2010, 09:44 AM
Muffin
Support Corvetteforum!
Muffin's Avatar
OK, maybe I am dense but can someone tell me how rockers make noise? You have it cinched down in the middle with polylocks which jam it onto both the valve stem and the push rod. Where does the noise come from? Now if we are talking about lifters, absolutely, little suckers will tick given the slightest opportunity. Don't matter if they are roller or flats. Tick....tick....tick.
Muffin is offline
To Best way (any way) to reduce hydraulic rocker/lifter noise?
Old 11-02-2010, 11:00 AM
PDQUIK95
PDQUIK95's Avatar
Location: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Roller rockers have less surface area touching the stem ,therefore less of an oil cushion against the valve tip at the roller unlike the conventional rocker arm that has a larger surface area with more oil film to help dampen the noise.You will find that the newer hollow sodium filled type valve stems have an even more unique tick to them than the solid stems.The tick actually comes from the momentary slack created in the valve train as the cam lobe unloads from full spring compression and the spring reachs a full closed unloaded position and the hyd. lifter vents remaining compressed oil to the galley not already normally lost thru the lifter seal and bore. The lifter plunger gets a new shot of oil for the next valve lift on the way up, but before it does the lifter oil venting and refill against the lifter plunger actually causes temporary slack and clearance in the valve train which results in the tick at the roller valve tip. The same noise principal applies for a weak or failing lifter. The oil demand and transfer during its cycle is greater because more of the useable oil in the lifter when compressed is lost thru either a failing seal (usually) or from excess clearance in the lifter bore preventing the lifter from reaching full lift with the plunger extended and this creates even more slack when unloaded causing the lifter noise that you hear when its going bad. I personally feel the hyd. lifter plunger is the true culprit that creates momentary clearance when loading and unloading as oil is transfered.Solid lifter noise is obviosly self explanatory with lash built in. So even with proper hyd. valve adjustment, there is still slack in the valve train from plunger movement that is only taken up by oil volume and is controlled by pressure unless you bottom out the plunger in the lifter when adjusting them and that would obviously be a nono. Sorry for the lengthy words but I hope some of it makes sense. I'm just thinking out loud.This is just my opinion but I have been wrong before.The post I see by engle below seems to also make sense though for the noise possibly being caused by roller tip bearing clearances.
Rick
PDQUIK95 is offline
Old 11-02-2010, 11:07 AM
engle1147
engle1147's Avatar
Full roller rockers have roller bearings at the fulcrum point those have a minor amout of "slop" in them as does the tip of the rocker that strikes the valve stem. As the tip and the fulcrum bearings get some time on them you'll notice the "slop" increases a bit. Stamped rockers are pretty much all 1 piece so no real "slop" there. The extra "slop" is what makes the noise.
For the most part a valvetrain can make extra noise if the geometry is "off" (pushrod length), too much preload or not enough preload. Thicker oil will not help with roller rocker noise.
Not sure if this helps: I read an article in "super chevy" magazine not too long ago that mentioned there was a low success rate for running 1.6 rockers with the newer XFI cams due to their higher "ramp" speeds....might be something to that or maybe not.
engle1147 is offline
Old 11-02-2010, 09:20 PM
USAsOnlyWay
USAsOnlyWay's Avatar
Can you clarify what you (they) mean by success rate?
I've heard that you want stronger springs than what Comp suggests to prevent valve float but I've haven't heard, or understand, why you couldn't run the 1.6s they designed the cams for.
They are definitely supposed to be nosier and harder on valve seats but haven't heard this...
USAsOnlyWay is offline
Quick Reply: Best way (any way) to reduce hydraulic rocker/lifter noise?
