lost power?
Old Nov 8, 2010 | 12:02 PM
Crowhater's Avatar
Crowhater
Default lost power?
This morning I nailed it around a corner and slid the car sidways to the driver side under power and the motor lost power until I got strait again. I had over a 1/4 tank of fuel. I was controling the slide with power until the motor tried to cut out. anyway what is lose, where is it , how do I fix it?
1990 Coupe ZZ4 crate, 2800rpm stall
Old Nov 9, 2010 | 08:07 AM
C409's Avatar
C409
It was probably fuel slosh ... at the strip , I momentarily lose power off the line if the gauge is under half tank ... my gauge readings are getting more vague day by day and I'm certain that it has something to do with 10% or less ethanol in every gallon of gas ... ...
Old Nov 9, 2010 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You need more fuel in the tank. Anything near a 1/4 tank and I suffer the same. I don't trust my gauge, so I try to keep at least a half tank minimum.
Old Nov 9, 2010 | 08:19 AM
Crowhater's Avatar
Crowhater
Thanks guys
Old Nov 10, 2010 | 08:05 AM
kenmohr's Avatar
kenmohr
YEP
Old Nov 10, 2010 | 09:40 AM
Txbobcat's Avatar
Txbobcat
Sometimes when my foot slips off the gas pedal the same thing happens to me. Check your foot also
To lost power?
