Service Engine Soon - No Codes
Old Nov 11, 2010 | 07:15 PM
VA50th's Avatar
VA50th
Default Service Engine Soon - (Update) - P1416
1996 LT1 Coupe Automatic
The SES light came on (solid) about 2 miles from the house. Car started and runs fine. Drove to the gas station for I was down to 4 gallons in the tank. Filled up. SES stayed on. I pulled the codes using a paperclip (12/4) and got C12....'---',...1. '---', 9. '---', A. '---', and 1.0
Doesn't look like any error codes are present.
Owner’s manual mentions things like changing fuel grades (been using Shell 93 for the past couple of months), low fuel level pulling in air, etc.
Any ideas?
I guess is the SES will stay lit until the symptoms go away..?
Old Nov 11, 2010 | 07:40 PM
tblt44's Avatar
tblt44
It was my understanding the paperclip works for pre 96,up to 95 only
Old Nov 11, 2010 | 08:26 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Since the 96 is odb2 you should be able to go by any auto parts store and have them pull codes for you
Old Nov 12, 2010 | 09:22 AM
oldalaskaman's Avatar
oldalaskaman
reset the light, see if it comes back, a voltage spike , up or down will sometimes turn it on, most times a service light with no codes is a mileage marker for oil change
Old Nov 12, 2010 | 04:54 PM
VA50th's Avatar
VA50th
Stopped by Autozone and I got the error code P1416.
Ideas?
Old Nov 12, 2010 | 06:06 PM
Deepa's Avatar
Deepa
Just googled it and it was something about the Air Check Valve.
Do a search on here, I found some info on the C5 Board about it.
Old Nov 13, 2010 | 12:19 PM
84vette96's Avatar
84vette96
Clean the check valve on the tube that comes up from the pasenger side exhust manafold. Do both sides clear codes and see if this works. It only costs $3.00 and about an hour. I use tb cleaner or carb cleaner. Good luck.
Old Nov 13, 2010 | 03:50 PM
RUU's Avatar
RUU
I had to do this on my LT4. I sprayed some TB cleaner into the hose and blew it through the valve with my mouth. If you have access to an air compressor, it would be a lot easier, I'm sure. Make sure you get TB cleaner that's safe for O2s and cat. converters.
To Service Engine Soon - No Codes
