Save my l98 vette
350 original Block bored and dipped to 355
Freshly rebuit.....
zz9 cam
zz4 Alm heads
24lb injectors
TPIS long tube runners
TPIS cer coated headers(eliminated two front cats)
Magnaflow cat
Magnaflow cat back exhaust
160 thermostat
52mm throttle body
2400 stall
Dana 36 rear w/ 3.73
TPIS Proformance chip
TPIS intake
So I took the car to the dyno. How disappointed I was. The car has 300rwhp and 400+tq. It Tops out at 3300rpm's. I need to move the power band. I would be happy with around 400rwhp. Not that i'm a racer but I brought the car to experience the 1/4 mile. One of the thing in life I always wanted to do. I'm not a mechanic and dont proclaim to be. So all work done will be subbed out.
My goal is to be able to respectfully finish the 1/4 mile. My objective is to gain 75-100 rwhp. In simple terms I have a corvette in need of Viagra! Something to wake it up!
Thoughts I've been given
1 mini ram or stealth ram
2 Replace cam and injectors
3 100 shot nitro
4 Piggy back a tune to the chip
I really dont think shooting spray into a topped out motor is such a good idea. I might be wrong ....but doesn't sound like a good idea.
I also dont think replacing the Cam and injectors is gonna solve my TPI intake problem.
Again all thoughts are greatly appreciated. I did alot of reading and reserch on this and .....It depends on who you speak with. It can be confusing at times. But because I'm only trying to increase my hp to 75-100 I needed to build a picture of whats going on.
Also need larger injectors and a real good tune plenty of guys here to help you with that.
Since you've already got too much gear for an LTR set-up, you could use a taller tire.
Check out the new Hoosier 28x10x17 drag slick, or 325/45R17 M&H Drag Radials.
Could be a low-mid twelve second car as-is with some traction.
A miniram is your best starting point for immediate gains (and in terms of price). I skipped mentioning the SR since you've got steep gears. It just might run out of breath before you're happy though. Again, it's the stock heads.
The tire idea is a good one too -- at least for the track. And, as you mentioned, how good is the tune?
FWIW, you're ~70hp above stock (with nearly an equal gain in TQ).
BTW: I bet the car is fun to drive. The intake is the main stumbling block for a track car. Heads don't help either. But, for a street car, obsessing over dyno numbers isn't going to do you any good. How's it run in the 1/8th mile?
Are you looking to be competitive with the guys that run every week ?.. (less than 10.5's) or just the street guys..?.. (11.00 - 13.00 range) ?
Also keep in mind....the faster you go.. the more things will break..!.. the IRS will most likely be throwing U-Joints or the Rear Gears if itself in that Dana 36, a 44 might last a bit longer. Trans and Staff are another point to look at.
Being Competitive also has a lot to do with driving, how well the car has been setup for the 1/4 mile launch.
The motor you have now FEELS like an 11-second motor from light-to-light. But, look at you. That's not enough. If you really go down this road, I'm betting $10k is what you'll spend before you're happy....or give up.
It's cheaper, retains a bit more low-end torque, and has a certain visual appeal.
Which is why you should be happy with what you've got. There's several ways to getting a faster car. I'm betting you'll need a better intake, better heads, and NOS to get to the low 11's. You're probably looking at $4-5k (for the cheapest route).
I don't call low 11' competitive in the 1/4 mile -- unless you're bracket racing. But, you could do that now. Once you drop $5k to get 1.5-2 more seconds, you'll get used to it quickly and wonder why you couldn't have been happy with that money in your pocket.
Been there,done that. If it feels good as a DD and your happy and "impressing friends" without timeslips - Leave it!
I'm not really interested in a hood mod. I wanna keep the outside as stock as possible.
I'm gonna start with the mini ram. I will probably start in Febuary and i'll take it from there. But Heads for the future any thoughts?
So you are already 50 rwhp over stock.
More air in should get you closer to your goals
