1986 Corvette Gauge Problems!!!!HELP!!!
Old Nov 26, 2010 | 12:31 AM
86Vette350's Avatar
86Vette350
Default 1986 Corvette Gauge Problems!!!!HELP!!!
Just bought a 86 vette, pretty much the only thing wrong with it is the digital gauge that's in it, the speedometer works and the whole gauge cluster lights up but nothing else works just the speed works, The information cluster in the middle works fine and lights up but when switching the buttons on it, it does't do anything on the gauge cluster only thing i can change is the speed to km. WHERE DO I NEED TO START, AND WHAT DO I NEED TO DO! PLEASE HELP, THANKS
Old Nov 26, 2010 | 01:40 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
At first it sounds like the harness connector to the cluster is loose.
It could also be a power supply on the dash cluster main board.
Some one will chime in with the web address for the DIY manual.
Old Nov 26, 2010 | 02:06 AM
86Vette350's Avatar
86Vette350
so JrRifleCoach u think i should just take out the cluster and check all the wiring?? just hope the cluster isn't busted or wore out, thanks again, is there anywhere on the web i can go to for trouble shooting with the cluster? thanks again
Old Nov 26, 2010 | 02:33 AM
JrRifleCoach
Like you asked, ya gotta start somewhere.
This will also help you master the removal install process.
I checked and the DIY Batee site is no longer listed for the manual.
There's bound to be one around.
Old Nov 26, 2010 | 03:06 AM
skyzzics's Avatar
skyzzics
Default Try this
My gage cluster had issues when I first bought my '89 coupe. Many of my switches were not functioning so I bought a can of air spray and shot some into my switches and worked them back and forth and that worked for some of them. Try that first. That was especially true of the switches associated with the outside mirrors.
Next step if that does not work is to pull the cluster and lightly sandpaper the contacts and maybe put in new bulbs while you are at it. It will only cost you some time and very little money.(a few bucks for the can of air.)
Old Nov 26, 2010 | 07:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://www.batee.com/corvette/dcrg/index.htm
Old Nov 26, 2010 | 07:32 AM
AGENT 86's Avatar
AGENT 86
Info from my 86 FSM >> http://members.shaw.ca/dankai/Instru...%20Cluster.pdf
Old Nov 26, 2010 | 10:39 AM
JrRifleCoach
Originally Posted by AGENT 86
Thanks. Bookmarks updated
Old Nov 26, 2010 | 10:55 AM
1985 L98/Z51's Avatar
1985 L98/Z51
www.Ecklers.com
Ecklers has an 1984-89 Instrument Cluster Service.
Old Nov 27, 2010 | 01:43 AM
86Vette350's Avatar
86Vette350
Alrighty thanks for the help and info! Rekcon I'm goin to start taking out the cluster and go from there, guess I have to start somewhere and learn from there ha, This is my first corvette, i only have 3 other mustangs ha
Old Nov 28, 2010 | 10:09 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Check the fuses first.
Old Nov 29, 2010 | 02:24 AM
86Vette350's Avatar
86Vette350
yeah i already checked all the fuses on the fuse panel on the passenger side and they are all fine, nothing blown
Old Nov 30, 2010 | 01:39 AM
86Vette350's Avatar
86Vette350
Alrighty i took out the dash and gauge cluster and found nothing wrong with it, i took it all apart and cleaned it and doubled check everything...still nothing only thing that works great is the speedometer and the gauge lights up good, could it be the information panel not working right? there was no glass broken on the gauge cluster still looked bran new...i'm stumped now..any more ideas anyone has??
Old Nov 30, 2010 | 02:43 AM
skyzzics's Avatar
skyzzics
Did you try my suggestions? Post#5.
Old Dec 1, 2010 | 02:00 AM
86Vette350's Avatar
86Vette350
yeah with air and new bulbs..then i used sand paper on the connector prongs and still nothing, now when my light are on i can see a lil of the tach meter bars more but u have you to look right at it to notice it, so i might just buy a new one or switch and go to regular gauges, would love to keep it all digital...
Old Dec 1, 2010 | 10:17 AM
sailorsteve's Avatar
sailorsteve
Remember that for a circuit to work, the ground side has to be good, too. The FSM will show you where to look for ground wires, studs, etc. GM ground wiring is usually black.
Old Dec 1, 2010 | 10:23 AM
engle1147's Avatar
engle1147
Any chance you can take a picture of the cluster and post it here in the thread. Take one with the cluster "off" and one with it "on".
Old Dec 5, 2010 | 02:17 AM
86Vette350's Avatar
86Vette350
Its all good now! My buddy had one just laying around in his shop and yeah, should have asked him in the first place ha new one works great now! thanks for the help guys!
To 1986 Corvette Gauge Problems!!!!HELP!!!
