93 Throttle position sensor
Old Dec 17, 2010 | 08:20 AM
BIGJIM13's Avatar
BIGJIM13
Default 93 Throttle position sensor
Guys
have a 93 Ruby with 85K miles - sometimes at startup it will jump a bit like an idle surge...lately low idle has been a bit rough...is the throttle position sensor on its way out?
Old Dec 17, 2010 | 08:30 AM
sailorsteve's Avatar
sailorsteve
Not necesarily- Check for carbon buildup around the throttle plates and IAC pintle. Also, look for sticking throttle cable that doesn't always return fully. And, check for cracks, etc. in vacuum hoses just while you're at it. Does this happen on cold startup only, warm startup, or both?
Old Dec 17, 2010 | 08:43 AM
BIGJIM13's Avatar
BIGJIM13
Thanks - on cold
Old Dec 17, 2010 | 08:56 AM
sailorsteve
So, warm startup and idle are ok?
Old Dec 17, 2010 | 09:00 AM
BIGJIM13's Avatar
BIGJIM13
warm start up ok - warm idle not ok
Old Dec 17, 2010 | 09:22 AM
sailorsteve
If your problem is intermittent, I would add to my previous suggestions, check wiring connections to CTS and check operation of EGR valve and its vac. hoses. It might be worthwhile to pull codes, can't hurt.
Old Dec 17, 2010 | 11:08 AM
BIGJIM13's Avatar
BIGJIM13
thanks
Old Dec 17, 2010 | 03:49 PM
BIGJIM13's Avatar
BIGJIM13
well - ran my codes - code 16
replaced the opti 6 months ago
Old Dec 17, 2010 | 03:59 PM
sailorsteve
Try clearing the code, then running the engine. If the code resets, post back, I can post the diagnostic page for code 16. Don't assume a bad opti yet.
Old Dec 17, 2010 | 04:19 PM
BIGJIM13's Avatar
BIGJIM13
I have the book for Code 16
will clear codes and see what happens
Old Dec 17, 2010 | 10:06 PM
pcolt94's Avatar
pcolt94
Here is a couple of suggestions to get the easy possible causes out of the way
1- Clean the MAF wires and throttle body (carefully using only throttle body cleaner).
2- Clean the IAC plunger and seat.
I just read a post about having a similar problem. He could not get the IAC seat and surrounding area clean while it was on the car. It had to be removed to be cleaned properly and it did fix the problem in that case.
You can always measure the wiper (might be DK Blue wire) of the TPS with a volt meter with the key on, engine does not have to run. Move throttle to open position while monitoring voltmeter. Voltage should go from about 0.4 volts to 5.0 vdc. Look for smooth transition. This would eliminate the TPS without having to remove or replace it.
Old Dec 18, 2010 | 12:02 PM
BIGJIM13's Avatar
BIGJIM13
will try the IAC
its a 93 - no MAF
Old Dec 18, 2010 | 01:31 PM
pcolt94's Avatar
pcolt94
Actually I know it does not have a MAF but could not think of the term for the unit. Is it speed density? Regardless, I think it still has the wires or resistor in it,,, I beleive.
Old Dec 18, 2010 | 02:30 PM
BIGJIM13's Avatar
BIGJIM13
I sure cannot find it...
I do appreciate your help/comments
Old Dec 18, 2010 | 05:14 PM
BIGJIM13's Avatar
BIGJIM13
well
cleaned up the IAC - not really that bad - and same condition...
starts off about about 750 650 idle and then drops off to about 500 and the rumble rough - so I guess its either a TPS or an opti weekend!
To 93 Throttle position sensor
