headlights cause fuel pump prime cycle!
a friend just recently purchased this car, someone has installed a fresh engine/trans. looks good. sounds good. runs good. no SES light. no codes (with the exception of one for a MAF circuit low, one time whilst i was scanning it, but havnt seen it sense after clearing it) i tidied up under the hood. verified all grounds i could come across. checked connections, connectors and so on.
with the KOEO if you hit the brake peddle or turn on the headlights or even the hazards or signals the fuel pump will complete a prime cycle.
that is correct... fuel pump, headlights.
other than that, car operates great.
i have disconnected, reconnected, tried with and without everything imaginable. literally. im figuring,that for some reason the ecm is getting a signal that it thinks is RPM and it is setting fuel pump cycle in motion, then when it sees it isnt running, it ends. everything is kosher between relay and ecm. even replaced fuel pump, maf, burnoff and so on relays just for giggles.
if i disconnect either/and/or the 4wire connector at the distributor, or either 2wire connectors at the coil the problem goes way.
if i remove all the bulbs in the car, the problem goes way.
i have added grounds temporarily here and there on these circuits in hopes of stumbling across the problem with no luck.
i guess more than anything after rackin' my brains all evening, then dismantling a perfectly good car, i just wanted to vent.
i think this evening i will try to isolate the problem by eliminating the lockup and braking circuits. sigh....
any thoughts, ideas, smart **** remarks, name calling and/or prayers are welcomed.
thanks-
Some times they tie those things into the lights.
I'd check to see if maybe they did some creative stuff with the "engine disable" portion of the aftermaket alarm.
Start looking under the dash under the drivers side for splices, crimps and cut wires.
You could try putting the bulbs back in selectively or one at a time, then seeing if the problem is still there, that could possibly tell you something.
