None actually. The power you get out of a motor is a function of the heads, cam, intake, CID, etc. Solid lifters only allow you to get more aggressive with the rest of your combo.......the cam in particular. There's really no reason to run solids on the street unless you're really pushing the envelope or want to be cool in your car discussions with other gearheads
Oh, one other thing..... a motor that makes effective use out of the gains derived by solid lifters is most probably not going to be smog compliant.
This is not a true statement, it all depends on what your goals are. If you are only planning to run 6000 RPM or less a hyd, roller will make the same power as a solid roller (within reason). If your goal is to run 6500 or higher there are benifits to solid rollers in power production. A hyd roller cannot have as aggressive ramps as a solid roller and the hyd roller will also experience some valve train control issues that require changes to the cam selection that limit the power. Hyd rollers are always leaking down when they run and higher valve spring pressures and higher RPM (6500 plus) will cause issues. If your goal is to make the most power at 6700 RPM or less, you will run a solid roller even if a hyd roller can operate in that RPM range. If you want power at 7000 plus you are almost alway limited to a solid roller design.
That is why you need to decide what your goal is, a SBC running at 7500 RPM is still a streetable engine (in case someone asks) it is just not as smooth as a stock engine at idle.
My goals may be different than yours but the fact remains that a solid roller can make more power then a hyd roller and it is not related to cool gearhead discussions.
I would not run one on the street.
Not because of the noise, but the other compromises required of an aggressive solid roller cam.
Everyone has there own idea of what a street car is, and solid roller cams exceed my limit.
Pete k, can you give more info.
Are you talking about bad idle/ part throttle quality due to a high duration cam that you would run w solid roller?
I imagine the exhaust smell, at idle, would be terrible.
Exhaust smell is the most underrated drawback to running a big cam.
It can get downright nasty to the point it deposits a smell on your clothes and people can tell you have been driving your car. Not cool
The only reason my Vette doesn't have one is that I don't trust the bottom end to spin to where I thought it would be a benefit (also started life as a short block for a ported TPI setup...) Of course now that I have the motor and tear it apart every couple of months for some reason or another...probably should've just gone solid anyway but the next motor will address that.
My next build will absolutely be a solid roller set-up. With todays valve train components and tight lash cams, a solid is completely user friendly (IMHO).
Right off the top of my head I have caught 2 top end problems before they cost a motor while running the valves. Also I consider the lighter more stable lifters a significant advantage.
What happens when there is real detonation and it doesn't back off the timing?
What about carb engines that don't have a KS?
You raise your spark advance get pinging under WOT load then back it off a touch.That is the max advance the engine can handle
Not sure how you would go about hearing pinging since I am not sure if the human ear is sensitive as the KS. Sure, if the pinging is horrible, you can hear it but if it isn't too much, you probably cannot hear it. Either way, you might be depriving yourself of timing at some other point on the curve by adjusting the timing manually. I thought the timing curve wasn't linear? If it isn't, I am not sure how you can advance or retard the timing without making wholesale changes.
I have never owned a carbed car nor will I ever own one so I haven't studied the system that much. AFAIK, at any rpm, there is an optimum timing number based on many factors. If you advance the timing like that, can you make minute adjustments at some points of the curve or at all points of the curve?
And as many of us have found out, the KS is too sensitive , retarding timing when it is not actually required .
Point I am making is plenty of Hi Hp carb engines run without a KS without blowing up.Tuning to audible ping on a dyno or on the street was means of choice for most to get max SA
Originally Posted by aklim
I thought the timing curve wasn't linear? If it isn't, I am not sure how you can advance or retard the timing without making wholesale changes. If you advance the timing like that, can you make minute adjustments at some points of the curve or at all points of the curve?
Not on a carb engine
Obviously with a ECM controlled dist you have infinite SA adjustments to suit all conditions
With a carb dist you can set start point ( initial advance) and end point ( total SA )
SA is controlled by changing the weights and springs to get desired ramp up and is linear
Base and mechanical advance; 3 or 4 pulls up a steep hill, various loads including WOT, across the rpm band. To set Vac stroke; after setting base, use a vac gauge and a streach of highway. Or a drag strip or dyno.
I'd do it again if the car had easy to remove valve cover access. Had a flat tappet solid- it really didn't need to be adjusted all that often, but I usually did before races and such.
On a strip with open exhausts it's impossible to hear detonation. Have to read plugs and compare timeslips. A wideband helps a lot too.
