Clacking or Clicking Electrical? 1990
Old Dec 28, 2010 | 12:53 PM
alrosenzweig's Avatar
alrosenzweig
St. Jude Donor '11
Default Clacking or Clicking Electrical? 1990
I have all new engine and I now hear above the valve covers what can best be described as a tappet noise but it runs pretty much ok. I know I need computer chip work but it almost sounds electrical, "arcing noise" and mostly at idle. Thoughts and advice are greatly appreciated.: crazy:
Old Dec 28, 2010 | 01:45 PM
pcolt94's Avatar
pcolt94
If you think it is mechanical I would pull the valve covers and have a look.
If you think it is Electrical, check out the wires and hot coil wire in the dark and look for arcing.
Does the noise change with RPM?
Old Dec 28, 2010 | 01:59 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
SBC in general is a noisy engine and you will hear valve train noise. Begin to worry if you don't hear anything.
Old Dec 28, 2010 | 07:56 PM
alrosenzweig
St. Jude Donor '11
thank you I will check.... my mechanic builds racing engines for many of the outlaws he doubts it's mechanical so we'll see. I haven't taken it back to him.
Old Dec 28, 2010 | 07:57 PM
alrosenzweig
St. Jude Donor '11
thank you ..and SBC.... stands for ?
Old Dec 29, 2010 | 09:54 AM
RLG's Avatar
RLG
Small Block Chevy = SBC
Old Dec 30, 2010 | 01:57 PM
alrosenzweig
St. Jude Donor '11
duh... of course..... thanks... what was I thinkin LOL
Old Dec 30, 2010 | 02:03 PM
alrosenzweig
St. Jude Donor '11
Default No arcing all new 4 bolt 350
Seems to be a bit quieter with RPM, I m beginning to think it's pinging or pre ignition as the rpm's increase it seems to quiet down (advancing in timing?) I think... too cold and icy here to drive it up to my engine guy and it has half a tank of mid grade gas with one container of octane boost and the gas its 6 months old... this should be a true 9.6:1 compression engine now. Also this now has no egr, no air pump (smog) no what was it spark retarder?? anyway I need to have computer chip tune work done but we want to get some miles on this engine get the gas out etc.
Old Dec 30, 2010 | 02:31 PM
alrosenzweig
St. Jude Donor '11
...I'm begining to think I need to move over to scan and tune... I also have a tach that bounces down at around 4000...I am thinking EST wire???? thoughts anyone/everyone.
Old Dec 30, 2010 | 03:32 PM
RLG's Avatar
RLG
the tachs on the 90's have some filter that goes bad. Mine reads several hundred RPM's off.
It's been my experience that detonation starts with an increase in rpm's, I have never had one "ping" at an idle.
What type of lifters were used in your new engine?
Rhoades lifters make such a sound at an idle.
Old Dec 30, 2010 | 07:07 PM
Jimbo 89's Avatar
Jimbo 89
Fuel Injectors......they sound like a sewing machine
To Clacking or Clicking Electrical? 1990
