Trouble shooting help
Old Jan 1, 2011 | 04:40 PM
My1st's Avatar
My1st
I also had spark until the pick up coil went out completely. When I did have spark I couldn’t even drive it you put the gas to it and it bogs and it died on several occasions at will. Just something to eliminate if it checks out good.
Old Jan 1, 2011 | 04:53 PM
87 vette 81 big girl's Avatar
I had a 403ci Oldsmobile powered car at one time with the Old Style HEI.
The pickup coil was defective also like you stated in your car.
Would run for a while and then die out without notice. Loose Ignition spark entirely.
Upon troubleshooting, one of the pickup coil leads became unattached at the coil. Right at the Soldered Joint connection.
When enough heat and vibration from the running engine, the pickup lead connection would seperate.
$28.00 for a NOS GM pickup coil and an hours worth of time with the HEI removed from the car, I had the problem fixed permante.
Never lost ignition spark again in that 403 car.
The owner of the 1989 Corvette may have the same issue also.
Not saying that isnt possible.
But none of us are there in person troubleshooting with him on his 89 Vette.
Only he is. Have to wait to hear back from him and see what he found out is the problem 1st hand himself.
We can only give troubleshooting pointers and tips for now.
Only 100 % Positive of the fix when he gets back to us.
Old Jan 1, 2011 | 05:11 PM
jfb's Avatar
jfb
Originally Posted by 87 vette 81 big girl
You can Impedance Test(resistance check) each fuel injector before your Corvette dies out again too.
Dont have to wait for it die out.
Usually when the GM Multec (1989-1996) fuel injectors are defective, the Impedance reading of each wont be different if they are cold or hot after running in the engine.
Good luck troubleshooting.
Let us know what you find wrong.
BR
Impedance is NOT the same thing as resistance! An ohmeter cannot detect a turn to turn short in a coil, but an impedance bridge which measures coil inductance and coil Q can easily find a turn to turn short. A turn to turn short will prevent all the injectors from working properly on that bank of cylinders. I found a defective injector coil on my 87 one time with an impedance bridge, the injector coil had half the inductance and half the Q as the other injectors, but my ohmeter showed the same resistance as all the other injectors.
A reasonable test for the spark system is to bring a grounded wire close to an unplugged spark plug boot while someone cranks the engine for a few revs. The spark should be snappy and at least 1/2 inch long. Weak spark can prevent an engine from starting.
Old Jan 1, 2011 | 05:20 PM
Are you an electrical engineer ?
Not many people a have impedance bridge to check a copper wound coils inductance with.
Surely not most Corvette owners at home.
Q factor.
Mutual inductance.
I do remember each from college electronics tech classes 20 years ago.
Old Jan 1, 2011 | 05:22 PM
GM FSM shows troubleshooting flow charts checking Injector coil resistance tests.
I didnt write the FSM. Coorvette engineers did.
Old Jan 1, 2011 | 05:27 PM
The inductance of a copper coil winding or CHOKE coil is actually measured in Henry's or Micro Henrys when Alternating current is fed through it in a circuit.
Do recall that too.
Old Jan 2, 2011 | 01:00 AM
jfb's Avatar
jfb
Yep, I'm a EE and I own two impedance bridges, both General Radio.
Old Jan 2, 2011 | 12:15 PM
desertmike1's Avatar
desertmike1
Another test you might consider is the (throttle position sensor) this could have a dead spot, or eratic feed back voltage, this a primary sensor that the ECM relies on in order to adjust the fuel schedule properly.
Old Jan 2, 2011 | 02:18 PM
HdRider04's Avatar
HdRider04
PROBLEM SOLVED........
I did a OHM check on the injectors and 1 is bad, disconnected it and car fired right up and back to normal... So a call to JON @ fic is in order...
Thanks for all the help guys!!!!!
Old Jan 7, 2011 | 11:52 AM
vabatwho714's Avatar
vabatwho714
I'm having a similar problem with my 91. I've done the fuel pressure test. 38 to 42 psi not matter how the motor is running. I check the injectors awhile back when I was having problems with my ACI and they were all fine. It will start and idle alittle rough. You can goose the throttle and it rev's up, roughly but it does. The longer the motor runs the idle gets rougher and it will bog down when you try to rev the motor. Will an injector get worse with heat or as some out here have suggested am I dealing with a cat?
Old Jan 7, 2011 | 07:58 PM
HdRider04's Avatar
HdRider04
That's how mine started, Then it got progressively worse. Ohm your injectors or disconnect them 1 at a time and start the car after each one and see what happens
