Fix for my abs and sys blinking problem
Old Apr 8, 2002 | 10:00 PM
tbmoore's Avatar
tbmoore
Default Fix for my abs and sys blinking problem
Do not know if you saw I fixed my problem. Found a two wire plug under the master cylinder which came loose or unpluged when I pulled the positive side of the battery to clean the connection. Was hard to see and get to but it was where two wires pluged together. Mine is 94 coupe. do not know about other models. This could cause intermite problems or just all the lights on all the time. depends on if just loose or unpluged all the way. Do not know where it goes but shut my system down. It was even with the battery and about 8in toward the engion under the master cylinder. Hope this helps. Terry
