Simple ball joint separator
Old Jan 2, 2011 | 06:45 PM
383vett's Avatar
383vett
Default Simple ball joint separator
I had to separate my lower A arm from the spindle last week in order to remove the front spring. Instead of using a pickle fork to separate the ball joint which I don't like doing because it can tear the grease seal, I used a 5 1/2" long 7/16 bolt with a coupler. Total cost at OSH was under $4.00. The bolt is placed between the upper ball joint stud and the lower ball joint nut which has been loosened. Simply unscew to coupler and the assembly will expand pushing the lower ball joint stud away from the spindle. The picture was taken after the fact, hence the cottor pin. Hope this helps someone. Willie
Old Jan 2, 2011 | 06:58 PM
ex-x-fire's Avatar
ex-x-fire
Thats a good idea, thanks for sharing it.
Old Jan 2, 2011 | 07:29 PM
Corvette0096's Avatar
Corvette0096
Very good idea.
Old Jan 2, 2011 | 07:52 PM
John A. Marker's Avatar
John A. Marker
Willie,
Great idea!!!
I will put that in my files for future use.
Old Jan 2, 2011 | 08:21 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If I didn't have an assortment of 3 jaw pullers that would be a cool idea.
Old Jan 2, 2011 | 08:33 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Good trick
Old Jan 3, 2011 | 10:11 AM
anciano's Avatar
anciano
Or you could use a torch to heat the steering knuckle where the ball joint stud goes through, and then hit the stud a good rap with a hammer and brass drift. Mine popped right out, and didn't require a lot of heat.
Old Jan 3, 2011 | 10:55 AM
engle1147's Avatar
engle1147
You are making these cars a little too easy for just anyone to work on with this tip/trick - stop it already!
Old Jan 3, 2011 | 02:44 PM
383vett's Avatar
383vett
Not really, I left out the part about making sure there was a jack under the control arm so that after the ball joint separates, the assembly won't come crashing down and break your leg. Actually, I did mention just to loosen the nut.
Old Jan 3, 2011 | 02:59 PM
esham's Avatar
esham
Thanks for the tip!
Old Jan 3, 2011 | 04:15 PM
slickfx3's Avatar
slickfx3
WOW perfect timing...
I suppose it would pop the tops as well....
Old Jan 3, 2011 | 06:04 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I've used this method on another car, and it does work well. If the BJ doesn't pop right away, just whack the side of the control arm beside the stud (with a brass hammer) while the bolt is under tension.
This tool also works well to pry open your wallet if you get work done at a dealership.
Old Jan 3, 2011 | 08:11 PM
Z51L9889's Avatar
Z51L9889
Just added a link to this thread to my "useful tricks" bookmark file.
Thanks for the tip!
Old Jan 3, 2011 | 08:50 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Old Jan 3, 2011 | 09:30 PM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Great Idea !
Chrome it, market it for $ 49.95.
Free Enterprise rules !
Old Jan 3, 2011 | 11:10 PM
383vett's Avatar
383vett
Originally Posted by larry93lt1
Great Idea !
I just filed for a patent number for this idea. Anyone who uses it can be sued for a patent violation. To avoid the subsequent penalty, just send me $5.00 per ball joint removal. We'll just use the honor system. Actually, glad to be able to help my forum buddies. Willie
Old Jan 3, 2011 | 11:22 PM
SJW's Avatar
SJW
There is much elegance when simplicity meets ingenuity. Well done, Willie, and thanks for sharing.
Live well,
SJW
To Simple ball joint separator
