Spring Preload
Old Jan 11, 2011 | 10:18 PM
dan_t's Avatar
dan_t
Default Spring Preload
Hopefully just a quick one here - I'm got an 85 that had base springs and I've just swapped in some 84 Z51 springs.
Now on the rear I had longer bolts for lowering. My question is do I set the nut at the same place it used to be? Doing so would mean that when jacked up the spring would have no preload on it at all (The nut would be a couple of inches off of the spring!)
Right now I've done the nut up so the spring has just started to preload. Its about 2" higher than it would normally be.
Old Jan 11, 2011 | 10:41 PM
bad-zr1's Avatar
bad-zr1
If the front is now a Z51 spring and the rear is also a Z51 spring I would NOT use the longer bolts. You want to keep the rear higher than the longer bolts will allow.
Are you going to autocross or road race the car? If you want to just use it for a DD then you can "soften" the rear by using the longer bolts but without "corner weighting" you will not get maximum handling. What shocks and bars do you have? What are your plans for the car?
Old Jan 11, 2011 | 10:44 PM
383vett's Avatar
383vett
Just lower the car and see where the car sits after driving around the block and adjust accordingly. Your current setting will be just temporary.
Old Jan 11, 2011 | 10:47 PM
dan_t's Avatar
dan_t
The more I think about this - the orginal bolts were to be set at a fixed position. I've never seen different length bolts offered for different years/springs so they must all mount in the same place.
Seems to make sense...
Old Jan 11, 2011 | 10:52 PM
dan_t's Avatar
dan_t
I'm now running 84 Z51 springs front and rear. 30mm solid front bar / 22mm rear. KYB GAS shocks all round.
I failed an inspection on front lower ball joints - I've had the springs sitting around so changed them while the front end was apart. Not ideal but its done now.
Its not a DD and gets driven hard. I want to do some AutoX and Road Course stuff this year if I can. Shocks and rear bar are already on the wish list
Old Jan 11, 2011 | 11:20 PM
bad-zr1's Avatar
bad-zr1
Then you are about 90% to where you want to be for autocross or road race. If you want to play in NCCC group 1 or 1S you need the stock bolts but other sanctioning bodies are probably not a problem. The longer bolts can be a "tuning" option. Get some good tires and have a blast!
A new alignment will really help.
To Spring Preload
