Oil Drain Plug Leak
Old Jan 18, 2011 | 08:27 PM
jrod954's Avatar
jrod954
Default Oil Drain Plug Leak
I have a 1993 Corvette Coupe and it is leaking oil at the drain plug. I just changed my oil and purchased new bolt and new gasket and it is leaking. Could it be that the oil pan is stripped? Is this a common problem? Any advise to fix the leak would greatly be appreciated!
Thank You.
Old Jan 18, 2011 | 09:49 PM
tblt44's Avatar
tblt44
mine is messed up from the p/o dameging the pan with a bad gasket/bolt,small leak but next oil change I will fix it better.
Old Jan 18, 2011 | 09:55 PM
mtwoolford's Avatar
mtwoolford
at one time parts houses carried slightly oversize drain plugs to address just this sort of problem. perhaps they still do ?
also, try wrapping the threads of your present plug liberally with teflon (pipe) tape.
Old Jan 18, 2011 | 11:44 PM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Also check to see if there is a fiber/nylon washer on the drain plug.
Old Jan 19, 2011 | 05:09 AM
HlhnEast's Avatar
HlhnEast
Teflon fixes a lot of thread problems You can even spool off a length of the tape, roll it into a string and wrap all of it at the base of the bolt threads and it will form its own washer. Make sure you wrap it in a clockwise motion so it wont spin out as you tighten it.
Old Jan 19, 2011 | 06:56 AM
redvetttes's Avatar
redvetttes
Little dab of rtv
Wait 15 minutes before adding oil
Old Jan 19, 2011 | 11:33 AM
anciano's Avatar
anciano
Mine drips a tiny amount, too. That's because I found the gasket in the oil container after replacing the plug.:o
I'll be go#$%&ed if I'm going to dump 5 liters of Mobil1 to stop a little drip that can wait for the next oil change.
Old Jan 19, 2011 | 08:31 PM
jrod954's Avatar
jrod954
thanks guys! I put a small amount of rtv on bolt head and it doesn't leak anymore. It was leaking pretty bad, not just a drop or two. I noticed a small gouge in the oil pan where the head of the bolt makes contact and may be causing the problem.
Thanks again for all the quick replys.
Old Jan 19, 2011 | 08:49 PM
tblt44's Avatar
tblt44
thats exactly how mine is,even with a new seal,still leaked.Thats why I do my own oil change and don't take it somewhere they do crap like that and damage your pan,plug ect.
To Oil Drain Plug Leak
