Rear end questions
Old Jan 19, 2011 | 08:08 PM
vetteguy22's Avatar
vetteguy22
Default Rear end questions
I am looking to replace the rear end in my vette. I just have a few questions I hope someone can help me out. It is my understanding that the 1985 with a manual trani had a heavy duty unit with 3:07-1 ratio as opposed to the auto with a 2:73. What pumpkin did these units have? Did they ever change to the heavy unit as standard on all cars or just with the manuals and if so when? I am hoping to find a heavy duty unit with the 3:07 gearing. What year car should I be looking for and does it need to be manual? any help would be appreciated.
Thanks, Rob
Old Jan 19, 2011 | 08:34 PM
John A. Marker's Avatar
John A. Marker
Your profile does not tell us WHERE you are in the USA. Check out this post Northern California.....
http://forums.corvetteforum.com/nort...36-3-07-a.html
Old Jan 19, 2011 | 08:45 PM
383vett's Avatar
383vett
You're looking for a Dana 44 found in 85 and up Vettes with manual transmissions (unless the car has been altered). It's a heavier duty rear with a larger ring gear and can take more abuse.
Old Jan 19, 2011 | 09:00 PM
rodj's Avatar
rodj
And you require the complete head/ batwing unit.
The D44 head does not fit a D36 batwing.
Also need a D44 DS and C Beam because D44 head is longer.
Other than that it is a bolt in swap using all your existing parts
Old Jan 19, 2011 | 11:44 PM
vetteguy22's Avatar
vetteguy22
Thanks guys, I really appreciate the input.
Rob
To Rear end questions
