security system
Jan 23, 2011 | 05:55 PM
5th Gear
security system
i cannot start my 85 after setting the security system. how do I over-ride this. i have tried to put the key in and turn on and then to lock as manual says with no results. electrical system seems to be working ok. nothing on the starter. how do i release the solanoid?
Jan 23, 2011 | 08:58 PM
Jan 23, 2011 | 09:34 PM
Quote:
Originally Posted by
oldalaskaman
what system do you have?
85 has a Starter Interrupt Relay , wired different to the Starter enable Relay on the VATS equipped cars
Jan 23, 2011 | 09:55 PM
Jan 23, 2011 | 10:08 PM
5th Gear
I am assuming this is the original system. this is the first problem I've had. when I shut the drivers door the system set, but when i unlocked the door the starter would not engage. thanks,
Jan 23, 2011 | 10:10 PM
5th Gear
the horn is non operating on this car. one of several things that need corected.
Jan 23, 2011 | 10:31 PM
2vetteguy2
when I shut the drivers door the system set, but when i unlocked the door the starter would not engage. ,
Maybe the switches in the door are worn and not working correctly
Jan 24, 2011 | 08:59 AM
Have you tried the passenger door lock ?
Jan 24, 2011 | 08:43 PM
5th Gear
not yet...good idea........thanks
Jan 24, 2011 | 08:58 PM
Jan 25, 2011 | 05:54 AM
5th Gear
