113 heads
Old Jan 24, 2011 | 09:39 AM
1986-z51's Avatar
1986-z51
Default 113 heads
How much lift can 113 heads take. There has to be a point were to much lift excedes what they will flow. I am putting a new cam an the lift is 444 with 1.5 rockers,If you use 1.6 then it changes to 473.Is it better to run 1.6 on the exuast only or all they way around????
Old Jan 24, 2011 | 10:43 AM
engle1147's Avatar
engle1147
I'm running ~ 540 on a set of 113 heads and they pull pretty hard.....but these heads have been reworked & ported and are nothing close to stock.
If your looking to see how much lift a stock valve spring setup will take on a 113 head I believe they will do 520 before you start hitting stuff. It is never a good idea to throw more lift on an already high mileage set of springs.
Do a search here on the forum this topic has been covered may times.
Old Jan 24, 2011 | 12:53 PM
Crepitus's Avatar
Crepitus
Originally Posted by 1986-z51
Is it better to run 1.6 on the exhaust only or all they way around????
Depends on what your cam and exhaust look like.
Flow seems to top off at about .500. More lift than that brings diminishing returns at the expense of working the valve train harder.
Old Jan 24, 2011 | 03:29 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The stock 113 springs can only handle about .478 lift but with new springs and no modifications to the head you can go as high as .525 lift. If I were you I would throw a new set of springs in with the rockers and you would be good.
Old Jan 24, 2011 | 03:35 PM
ch@0s's Avatar
ch@0s
I used the Hot cam spring kit on my 113 heads. That gives you up to .535 lift.
Old Jan 24, 2011 | 06:02 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Run 1.6 on both sides. When people consider a 1.5/1.6 combo on a TPI setup, it usually works better to put the 1.5's on the exhaust side. That's because exhaust duration is typically more on an off-the-shelf cam. (Extra duration helps in place of extra lift).
To 113 heads
